Wow, a mess indeed! As stated, the twin turbo Z32 is a really, REALLY bad place to begin learning due to complexity, and VERY tight working environment plus costs due to the need for replacing ALL suspect and worn items, NO exception for best results. Z1 and Concept Z and Specialty Z will become firmly attached to your bank account, and you will perfect a whole new range of curse words and other choice comments for Nissan engineers, who while creating a really really good car did so while also creating a service nightmare...perhaps on purpose.
You definitely have your work cut out for you, and will learn a LOT doing all of this. Part of your learning will be when to cut your losses and have a pro do some things for you if that possibility exists, because most likely your engine needs a major overhaul of all of it's seals and complete turbo system...possibly and probably including new turbos.
The problem you have is that a boosted engine means that the entire engine is under positive pressure, which in your (and previously my own) case, means major oil and boost leaks. Boost leaks are also vacuum leaks without boost (normal driving) which all in all taxes the turbos which if not already worn out, will soon be pushing against nothing (massive boost leaks). These leaks usually are from the lower turbo piping clamps that have loosened or rotted hose, or both.
Coupled with probably incorrect boost controller surely set at higher levels from the crackhead (I had similar butchery but hidden well) and surely bad early style injectors/connectors, plus other corroded connectors and questionable wiring showing throughout the bay, you face many many hours of work simply to replace the injectors and fuel rail, connectors, harness, and IACV/PTU harness/CTS sensor connectors, correct all vacuum hoses and wiring plus add a correct boost control setup, and many more small little things that are hard to communicate here...they become obvious as you progress.
The online service manual has a lot of valuable information and especially tests for various issues which I have used most of, and are very helpful. tt.net has many how-to's and various information as well that is helpful. Plus there are many good members here that can help with direct questions and insights but it's a lot harder when there is SOO much to go over...bottom line is ask away with specific questions in titled threads for best results rather than ask indirect questions in a longer term unfolding thread like this. By all means keep this thread updated and running, but ask your direct questions in separate threads.
Oh, and also if you look at my build thread attached to my sig, near the end I detail my own hunt and struggles dealing with basically what I suspect you are facing so you can get some ideas and insights there as well.
Good Luck, hope you have some large cajones (and small hands!!!) my friend!
