ok perhaps i can help here, the NEO rb25det is a 280hp single turbo engine, it is a 2.5 liter still, and the only major difference between it and the previous models of the rbseries is the VVT, and becuase of the VVT the head design is different, but everything else on the engine is the same as previous models.
Yes stock it is RATED at more hp then previous models of the rb series, and yes it does produce more then 280hp to the wheels. it uses a 5sp transmission for both the auto and manual if im correct, though im not to sure, but the mounting and everything are pretty damn close to the previous model of the engine (the rb25det out of the r33) but beside the VVT not much has change, and the hp is not that much more then a base rb25, but the VVT is quite nice to have if you wanna build it
BTW there was a 240sx with a neo rb25 in it for sale on ebay a while back, it was producing 554 hp at the wheel and around 800hp at the crank.
