SlowTK »
https://forums.nicoclub.com/slowtk-u34994.html
Sun Jun 03, 2007 2:26 pm
S13 blacktop in a S13. Basic mods and no gauges to read anything When the motor went in, the car ran great and had good power. As of the last month or so, the power has dropped quite a bit and it seems to run out of fuel at the higher rpms.
First and second gear seem to pull about the same all the way through the rpms (minus the lack of power that it once had) but in the other three gears, once you get around 4k, it feels like it's hitting a speed limiter. It'll still pull but with major hesitation, which is a bit nerve rattling.
Cleaned the MAF sensor and same results. Should the battery get disconnected and reconnected after the the cleaning, in order to reset the ECU?
Also, any ideas and/or suggestions on which direction I should be going with this, in order to get it running where it needs to be? Thanks
