Bonusplus 1, first off, welcome aboard! Next I did some searching for you and found this thread:
zerothread?id=203707. There doesn't seem to be a write up yet but there is some helpful info in that thread, so check it out. Also if you provide good pictures of your problem someone might be able to give you some guidance towards your solution. Also look for AZHitman because he has removed his top before and made a sweet tonneau cover for his vert! Glad to have you with us and try to do a write up with pictures if you have some friends handy to help you out. It would be a good way to make you legendary here, quick status!
