float_6969 wrote:Has anybody gotten the VH45 MAFS to work on the CA18 w/nistune before? I was told by another tuner that it was too big for the CA18 and that it was really hard to get it to idle properly and start.
Honestly I'm starting to have my doubts....because Nistune gives some message when you try and switch a .BIN to VH45 maf, says "VQ map lengths differ, trunctuating". I'm not exactly sure how that will effect the tune, probably means the cells will all need updated/tweaked =/
*edit* Ok, the Z32 maf gives that same message....so.....I'm not sure about that. Have you figured out the "halve values" option when changing MAF's? Does that box need checked?
Correct me if Im wrong, but wont unplugging the MAF be the test here, and if the idle corrects itself then it's the maf?
Modified by mbmbmb23 at 10:09 PM 9/17/2009
Modified by mbmbmb23 at 10:29 PM 9/17/2009
