SHIFT_COUPE wrote:CVT or MT? How are your driving habits?What kind of gas do you put in it?
Personally, I drive very fast and use manual mode CVT all the time. I get 20.2 mpg usually. I do a mixture of highway and backroads driving.hydro94530 wrote:I have a CVT and I only drive 10 or so miles a day on average (I don't leave the city too often). I do live in San Francisco so the bulk of that is on city streets and there are a lot of hills here of course. The mpg still seems low to me but with the info I just mentioned, does it seem right? I also put in premium only.Modified by hydro94530 at 11:05 AM 6/17/2008
Now I'm worried. I will double check to be sure. Is there any difference between regular gas and premium? Does one give better gas mileage than the other? I only use premium and I'm wondering if maybe that's part of the problem as I've heard it can be better to use regular, may not be true. What are your thoughts on that?maxentropy wrote:
You should expect, at the very least in downtown San Fran 16-18 mpg. And thats if there is a crapload of traffic.
Doublecheck your mileage, there is definitely something wrong if you are getting 10 or so mpg.
Thanks guys. quickshift, I'll try that with the tank I have and see how it goes. Maxentropy, I have a 3.5 and have been given varying opinions on what type of gas to use and whether it makes a difference. Also, yes the engine is EXTREMELY new. Since I never leave the city I only have 345 miles total right now since I bought it. When would you expect the engine to be borken in. Is it more a sustained speed for a period of time type of thing, or a certian amount miles driven in total? The possible causes you mentioned above seem like things I could check myself, is that the case? If nothing else I guess it would be easily identifiable by a mechanic if there was a problem. The car drives perfectly so I'm hoping it's more related to what you mentioned. Maybe I need to take a road trip, but am I correct in assuming that the gas mileage will go up once I get a decent amount of use out of the engine? FInally, the possible causes you mentioned, would any of these be easily noticed through normal driving? Sorry for all the questions, just want to make sure my baby isn't going to get worse. Thank so far for the help.maxentropy wrote:Good question about potential causes (if you do have an issue).
Could be a bunch of things;-super low tire pressure-dirty air filter-dragging brakes-fouled fuel injectors-spark plugs spacing issue-bad O2 sensor
Honestly, the items above barely happen to most people, but they are all possible. Do you have the 2.5 or 3.5?
I also noticed you've only had your coupe for a month or two. Have you broken it in yet? (driven it hard and fast for a bit)
If not, the engine is still new and you need to clear it out by breaking in the engine. Just be safe about it however you do it.
I thought all a/c's had 20 gallon gas tanks? I've got a 2.5 so it could be different, but I thought they shared the same tank.hydro94530 wrote: I know the tank is around 16-17 gallons and I'm only getting about 170-180 miles per tank.
You are correct, both the 2.5 and 3.5 share a 20 gallon / 75.7 liter tank.vballer22 wrote:I thought all a/c's had 20 gallon gas tanks? I've got a 2.5 so it could be different, but I thought they shared the same tank.
maxentropy wrote:No problems. If I were you, I'd top my tank off and reset the odometer to double check your exact mpg before worrying too much.
Honestly, the things I mentioned are rare cases and happen further down the road. Your car is brand new so it's most likely you just need to continue to drive it and break it in. Plus, you are in high hills and traffic areas so you may likely end up getting 16-18 mpg anyway. Generally I've read that car engines give better mileage the older they are-- it's the other things I mentioned in my previous post that reduce mpg later on.
To break in the engine different people recommend different things- here are a few threads to look at:
http://forums.altimas.org/zerothread?id=322283
http://forums.altimas.org/zerothread?id=333783
http://forums.altimas.org/zerothread/200474
Myself?
GAS: I used to use only 93, switched to 87 4 months ago or so since prices rose and haven't noticed a decrease in performance at all. 3.5's suppossedly provide better performance when you fill them with 93, but 87 will NOT harm the car. Remember, 93 is recommended which means 87 is still acceptable for your car.
BREAK-IN: Like I posted in one of the threads I linked above about breaking your car in-- I drove it like it's stolen Seriously though my recommendation to you is to simply drive your car like you would normally drive it.
Keep us posted and Gluck!
Thank you so much, I will go through these and make sure to follow these steps. One thing I find interesting is actually the gas range feature. Let me explain; the reason why I thought it was a 16-17 gallon tank is because when it brought up the whole "low tank" warning saying I had 15 miles left, I went ahead and filled it up and it only filled up to 16 gallons. I'm now wondering if I actually had 3 gallons left and the thing is just way to sensitive. I'm now thinking I might of had another 40 or so miles left. I'll do what you said though and top it off and start over and see. Is your're low gas warning just as finicky? I would figure that if it really was that low it would tell me on the last half a gallon or so. In any event thank you for the tips and I'll post back here after I tryt his out, hopefully Ill be good for the next few weeksmaxentropy wrote:No problems. If I were you, I'd top my tank off and reset the odometer to double check your exact mpg before worrying too much.
Myself?
My pleasure boss. The low gas indicator usually comes on for me when I've got 40 miles or so left as well. Better to know sooner instead of ending up with an empty tank of gas!hydro94530 wrote:Maxentropy, just checked out those links, great advice. Since I don't leave the city too much, I think I'll take a nice drive once a weekend for the next few months. Maybe like a 90 mile round trip and see how it goes. Still wonder about that damn low fuel warning tho.
Okay that make sense, I guess that would at least put my total mileage to about 210-220 right now. On some of those links you sent, they mentioned using manual for a while, you think that holds any water?maxentropy wrote:
Yeah that seems to be the case so far. I'm still going to take some drives on the weekends and track the mpg carefully just to be sure though. The mpg/mph on the display is actually showing only 8/8, so I'm not totally convinced that nothing's wrong.08altima35 wrote:i grew up in san fran and know that the hills in the city will absolutely destroy any kinda gas mileage your car is capable of. the manufacturers advertised city mpg was not intended for san fran hills dude. i doubt you would even get 15 mpg if you owned a yaris and lived in north beach.
Interesting, good point LBC, didn't think about it that way.LongBeachCoupe wrote:Everyone is forgetting the golden key.. that the computer counts sitting time...
If you have your car sitting in your driveway running (waiting to pick up a friend) that time standing still, is calculated into the cars avg MPG, and your avg spd and MPG will decrease accordingly.
Hills KILL! To see how that works, reset your mpg at the bottom of the series of hills and ride it up, see what it tells you. Now if theres any lights on the hill, your burning more too!
Yeah that makes sense since it has to calculate everything from the moment the engine is on. For me, every morning I warm up my car for a good 8-10 minutes, so idling like that every morning definitely would have an effect I suppose. Do you guys think warming the engine up in the mornings is even valuable? I always hear varying opinions on whether it matters or not. I hear it's good to do it at first while your breaking it in, but I'm not sure if even that is correct or not.LongBeachCoupe wrote:i realized this because i wanted to see what the MPG would be going to Carlisle from my friends house... I was waiting outside for him for a half hour... and i noticed when it said i was getting 3 mpg!
Nice, been doing it so far, so I'll keep it going. Thanks dudeLongBeachCoupe wrote:DO IT... especially before you hit 2k miles...
its best to let the car heat up till it idles at 1k rpms
Its actually always pretty warm here. I don't time it, I just watch the temp gauge and warm it up until it gets to the middle, or where the gauge normally sits while driving. No need to do it for that long? I honestly have never watched the tacometer before while warming up, is that the best way to go?xeene wrote:how cold does it get in cali? warming it for 8-10 min? i've never done that long in -20 windchill michigan winter. when your rpms hit 1k, you're good to go. stop wasting gas!
Cool, learning a lot here while sounding like noob too, lol. Thanks though, that should help with gas too of course.LongBeachCoupe wrote:your car doesnt need to be mid temp to run safe...
Just wait till it hits 1k
