Need Some Good Advice Here ( Oil Return Line Scavenge Pump )
The All Mighty KA-T
Car: 1995 Eclipse GS-T
OK, 1st off, i want to say that i have done my homework and i have read ( WDRacing Thread : zerothread?id=113171 )
Now with that out of the way, ill tell you all what my problem is and how i plan to fix it.
My problem is that i taped into th oil pan to low and the oil is backing up in my oil line and now i have a smokey turbo, i'm running the T25 setup with a SSA manifold and the turbo is really low and its hard to find a spot to drill into the oil pan so i can return the oil without it backing up ( P.S. if anyone here is running the T25/T28 setup, please let me know were you drilled into your oil pan b/c i cant find a spot thats vertical )........so i read up on WDRacing Thread and i found that the only problem was that you need a pump that can run dry and that you need to have a vented oil return line so that the oil pump will not suck too much oil from the turbo and blow the turbo like WDRacing in his project.........
But i think i have foud the answer to all the problem that he had and that other could come up with.
Here it is : The Westech Modified Turbo Oil Scavenge Pump
The info about the pump :
http://westech.home.mindspring...3.htm
The web site of the pump : http://westech.home.mindspring...p.htm
Now this is what i was thinking about doing running a oil - 10an oil return line vertical to a tee off then run a hose from the tee off to the pump and run a hose from the pump to the oil pan were i had tapped into.....now at the hole i left open at the tee off i'm going to run a hose 3 or 4 inch up so the oil will not run out but the pump can still suck air ( so i dont blow my turbo like WDRacing did ) if there is no more oil for the pump to suck.
Well what do you guys think?
i wish i could run a top mount turbo setup,b/c its really easy to run a vertical oil return line ( LIKE IN PIC BELLOW ) with a topmount setup on a KA- but i dont want to buy another turbo and stuff.
EZ top mount KA-T oil return line : ( !Keep Reading Below the Pic! )
If anyone running a t25/t28 bottom mount KA-T setup and you could get me a pic of your oil return line into your oil pan.....that would help me out alot! so i dont have to spend $130.00 for this oil return pump.......thanks
gaehrings13
Car: Nissan S14
weld the hole that you made, and make the new hole closer to the top of the pan, Im not running a t25 setup but im pretty sure you would be okay with that.
Trust me I know you don't want to take off that damn oil pan again lol.
The All Mighty KA-T
yeah.....i know what you mean.....this is my 2nd or 3rd time taking it off.......its not that ban anymore since i've takin it off so many times......lol......but i guys ill do it the right way this time.......thanks for the help..................
Florida240sx
Pic of your current flange location??
pr240sx
Why not drill into the block or the front cover?
You can also, use a reservoir to receive the oil and pump it back to the crankcase.You will need more oil in the system though
