Hi Snail,TheSnail wrote:It does need modification. You have to modify the the oil pan baffles, then you need to cut the 3 plates off the back of the oil pan since the 26 has them coming from the block in stead of the oil pan. Then you have to cut and weld a semicircle peice onto the oil pan for the oil pick up to clear since the 26 oil pan is 1 inch wider, but has two sets of bolt holes, 26, 20-25. Once you are done with that, you need to bang out the oild pan from the inside a bit since the pick-up as a bit too long. Before I did this I though (by the internet) that the 25-20 oil pan just bolted on the 26. After hours of messing with it, I called mickiney to see what they had to do, and they did not know, but just sent it to be fabed up and said it was the most ***** part, and I admit, it was the most ***** part. So I spent 6hrs modifying the oilpan. Here is a pic, its a ****ty pic, so I will take another one next time my car is on the lift.
-Snail
Yes, I cannot figure a swap like that out:-)Nameless EJ6 wrote:You don't have to weld anything. You cut the baffle plate a bit and that's it.
You don't need pictures. Put the pan up to the block and you'll see what you have to do. If you can't figure out a little bit of fab work you won't be able to complete a complicated swap like this.
I believe it will hit the sway bar, and it might not clear the crossmember with that diff on the front.BoostsFed wrote:why not modify the stock rb26 pan? cut off the drive shaft that runs through it and patch up the holes??
btw! i think you guys should use the grey color rtv sealer...the orange color looks funky.
I believe that is the NISSAN issued sealer you see on that pan...what better to use thant he stuff with the engine manufacturer's name on it?BoostsFed wrote:btw! i think you guys should use the grey color rtv sealer...the orange color looks funky.
What about sway bar clearance? Which mounts do you have? S13?Ramius83 wrote:I used the stock RB26 oil pan.
The differential itself is separated from the actual engine oil. It uses diff. fluid as with any other diff. We cut off the whole diff housing itself, and the opposite side CV axle plate. You do NOT have to cut the rod off that is located in the center of the actual oil pan. Even with two holes on each side of the oil pan, it will NOT leak because that center rod in the oil pan is perfectly sealed off.
that's is exactly what i was implying. the gtr probably use the same crossmember, so i'm assuming the 26's oil pan will clear.Ramius83 wrote:I used the stock RB26 oil pan.The differential itself is separated from the actual engine oil. It uses diff. fluid as with any other diff. We cut off the whole diff housing itself, and the opposite side CV axle plate. You do NOT have to cut the rod off that is located in the center of the actual oil pan. Even with two holes on each side of the oil pan, it will NOT leak because that center rod in the oil pan is perfectly sealed off.
Hi, when you say made a custom swaybar does that mean you customized the OEM bar or made a one off bar? I had a feeling the swaybar was going to be in the way. I could tell just by looking at. Its in a bad spot. I'd like to see a few pics if you would. Also if its a one off piece then will you be making any more for sale?Vrtgrumpy wrote:Its not the Diff that hits..... The front of the oil pan is totally different then the RB25. The big part in the front of the pan (RB26) is what hits. I have the RB26 oil pan in my S13, currently with no sway bar because of the pan (I haven't driven the car since then, so who needs it). But we did just did one on a S13. The gold S13 that was in Import Racer, we changed it to the RB26 pan and made a custom swaybar for it.
If you guys want i can take a pic tomorrow to show you that it does hit the sway bar area.........................
Grumpy
That custom sway bar that you guys did, is it bigger than stock? Solid? How much?Vrtgrumpy wrote:Its not the Diff that hits..... The front of the oil pan is totally different then the RB25. The big part in the front of the pan (RB26) is what hits. I have the RB26 oil pan in my S13, currently with no sway bar because of the pan (I haven't driven the car since then, so who needs it). But we did just did one on a S13. The gold S13 that was in Import Racer, we changed it to the RB26 pan and made a custom swaybar for it.
Grumpy
so do you have the pictures ?Vrtgrumpy wrote:Its not the Diff that hits..... The front of the oil pan is totally different then the RB25. The big part in the front of the pan (RB26) is what hits. I have the RB26 oil pan in my S13, currently with no sway bar because of the pan (I haven't driven the car since then, so who needs it). But we did just did one on a S13. The gold S13 that was in Import Racer, we changed it to the RB26 pan and made a custom swaybar for it.
Grumpy
