Hope?JdrifterCA wrote:Hey guys im racing a 08 civic si this weekend. I have a stock s13 sr20 black top 3'' fmic and koyo rad. I need more boost if i wanna win. wut cna i do? without boost controllers. lolz
what do u mean dont drop floor pan out? I have no idea what that is lolz. and thanks for ur adivce... now which line is the one i have to unplug? sorry for being stupidburntricer wrote:
just dont drop your floor pan out, and be carefull, you might endanger your manifold.
Thats true, I hadn't though about how fast a New Si actually is. I haven't driven one yet.supreamS14 wrote:If he's stock and beats you then somethings wrong there. Hondas have poor torque curves. Plus a 08 civic is about 3000lbs stock where you should only be at about 2500lbs.08 civic maby 200 crank hp @3000lbsA SR20deT is 200hp @ about 2300-2700lbs.
You should take him @ stock boost if you can hook! Unless you have a open diff then your screwed no mater how much boost you run.
Actually Ive had the wastegate line blow before. Its really fast till about 3000 RPMS, then it hits fuel cut. Which is not so fast.burntricer wrote:the wastegate, you need to unplug it, its the vacuum line that attaches to your turbo, just un hook that, your engine might not last, but it will be WAYYY faster then his car.
No he is not stripped and yes he has a r32 diff. And whats funny is hes not the best driver either. My buddies have ran mid 13s on stock sr's. You just need to learn how to drive them.JdrifterCA wrote:No way, how did ur s2k lose to a stock sr? was his interior striped. does he have a diff?
JdrifterCA wrote:LMAO LMAO LOL @ CIVIC SI.I beat him,08 honda civic si, so bad a**. I was leading the whole way.but is kinda of an unfair race because the driver is a true ricer. His tires were bald, 2nd gear grins, a 3000 dollar body kit, obessed with his lil torqueless vtec. and most of all, he is a poser saying he know every thing about cars and duct taping led lights under the car is cool.
We took off , and i started to pull away really hard.. since 1st gear. we got pass 1/4 mile at least cuz we went to 100 mph than stoped. He was way behind.... he was tiny in my rear view mirror.
This goes out to all the sr20 owners! WE CAN SMOKE CIVIC SI NO PROBLEM
My car specs13 sr20det @stock boost, 3'' fmic, koyo rad, nismo mount, open diff.
supreamS14 wrote:Hondas have poor torque curves.
supreamS14 wrote: Hondas have NO torque curves.
Omfg I had to road test the car for a used car safety check. It took for ever to hit red line in first then shift to second. Vtec screaming for no reason.idahotuner wrote:EDITED
but seriously the new si is not impressive at all.
