its not just about a few HP when it comes to parts, like i said its about overall build quality and reliability....so if I were weighing spending $500 on headers that might have to be replaced because they might rust and that means spending another $500 and doing the work all over again, or paying to have it done....or spend $200-$300 more and get the stainless steel (some stainless headers are of a different grade steel then others) headers that wont rust through, spend some more money and do it right once...I look at those crap intakes at autozone, knew someone that put it on his Honda, the glue that holds the filter on failed and it fell off...it sounds like you want to keep this car and build it, thats why I think its worth spending the extra $ on the parts you put on it...
http://www.autopartswarehouse.com great place for OEM parts (brakes..etc)
unless there is something wrong with the engine 122K isnt a ton of miles for that motor...got a friend who has a 96 with 150K and hes got some boltons and runs it pretty hard and its still goin strong...that motor wont have any trouble handling all the boltons you can put on the car...its when you start adding boost or crazy amounts of power that you want to start building the bottom end...id just make sure your timing belt (think those are belts) has been replaced at some point, if not then replace it sooner then later...do little things like changing the coolant and fuel filter, change your trans fluid since you have an auto, make sure the plugs are good and run intake and fuel system cleaners (BG makes good stuff)...if you dont have to worry about that stuff, then id start moddin
Modified by 2K2WhiteMaxSE at 9:16 AM 10/17/2008
Modified by 2K2WhiteMaxSE at 12:36 PM 10/17/2008
