need ideas too mount grille screen
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
evil200000000
Car: Black Versa HB 1.8SL CVT
i just made these screens to put over top of the existing grille but have no idea how to fit it in. here i just use 3M double sided tape to stick on so i can take the pics. what do you guys think and how should it be fit on?
http://memimage.cardomain.com/...l.jpgh ... m/...l.jpg
Atx_Versa
Car: 2008 Nissa Versa SL
I like that idea, looks good definitely a different grille set up than the rest of them out there.
As far as the mounting......I have no idea but sure someoneee will chime and post you some recommendations.
srellim234
Car: 2007 Nissan Versa SL hatch w/CVT
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
I put my galvanized mesh on the inside of the grille using black zip ties. I got the idea from Versa Madness. Here's his look with pictures:zerothread?id=331470
Doesn't make the car look different but I was looking for bug and road debris protection for the radiator, not appearance. If all you're looking for is protection, you could mount yours the same way.
If you are looking to mount it for the "look" you can use the zip ties and mount the mesh to the outside, but I don't know that the edges will look very refined.
lain
ew...
srellim243's has a much cleaner look.
by you putting the mesh over the grill...idk it just doesn't look right.
i was looking at the picture again and it could be that the mesh is a dark gray?also the chrome around the mesh might be throwing off the tone of the car..
Modified by lain at 8:34 AM 7/23/2008
evil200000000
im not really digging it too..those are actually 1/4" perforated stainless steel sprayed on with flat black. i dont like the sharpy edges. if i do decide to put it on, i'll put a strip of metal on the outside to get that flat, straight edge.
Johniboi
Car: Versa
dont be dumb-buy the versapeed grill.
Versa Madness
Car: 2008 Nissan Versa S HB 6 spd
srellim234 wrote:I put my galvanized mesh on the inside of the grille using black zip ties. I got the idea from Versa Madness. Here's his look with pictures:zerothread?id=331470
Thanks for the shout out srellim234!!
srellim234
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
You're welcome. I believe in giving credit where credit is due.
BlueMango
Car: 2008 Nissan Versa S Hatchback
I haven't pulled the grill off before so this might not be possible but I'll throw it out there and maybe someone else will know...
Is there a way to get it behind the chrome but in front of the grill? It might even be more secure if you could.I think that would look much cleaner than putting a metal strip cross the bottom edge.
Versa Madness
You could use a dremel tool or another cutting device to remove the portion of the grill behind your new mesh but then leave mounting "tabs" in the corners where needed and attach with small screws or pop rivets. The heads could be painted black as well for a clean look.
Return to “Versa Technical Discussions”
