I have searched for an hour, trying to find how to get the codes without a scan tool. I found this but I don't think it will work for ouyr years of Maxima.
The blinking OD light is usually a code from the transmission control module. The CEL is when you get a code from the ECU.
You can try this, as far as finding out the transmission codes. Link:
zerothread/213507
I am not sure if it will work or not, since the cars are a generation apart. I'll keep looking for you. If all else fails, you can pick up a cheap scan tool at Autozone for about $30.
