need help with SR20det swap
forthebledones
Car: 90 240sx
its starts but does not want to run. i have checked the timing and its in time. any ideas as to what could be causing this. also i keep blowing three fuses for some reason and i cant figure it out either. the hazards, the wipers, and the turn signals, ive gone over my wiring and everything seems to be fine any clues?
schanne
Car: 93 Hatch-Sr20
Search around and look for your answers. zerosearch
Theres a lot of different things it could be so research and give nico more information so we can help!Welcome to nico
forthebledones
Car: 90 240sx
well i worked on it today some more and im not sure what is the matter. i think i have hooked up everything correctly but it doesnt want to run. it starts but will idol very rough and cut off, or it will rev up but not consistently. i noticed today though around the turbo there was smoke. i think there is a intake problem or the MAF sensor has gone bad. if anyone has any other ideas please help.
forthebledones
Car: 90 240sx
i noticed that im using a SOHC MAF, does that make a difference in the air flow? should i be using a DOHC MAF from a DOHC KA or Z32?
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
The SOHC MAFs is the one you want, you would need to retune for the others, Im guessing the smoke is just oil burning off the exhaust. It sounds to me like you should check the MAFs voltages, also check the TPS.
forthebledones
Car: 90 240sx
alright what should the MAFs be getting in voltage and what is a TPS?
