Pathy24 wrote:picked up the maxima mfc from the dealer for 70 bucks they looked at me like i was crazy, the techs came out to listen to what i was going to try, they want me to call them tomorrow if it works...anyway , fit right in no problem
crossed my fingers and started it up, at first it was idling at 3 grand, then over about 10 minutes it gradually lower and stayed at 700rpm, took it for a ride....Its like it was new...even better. Spark Knock is GONEthe acceleration is unbelievable and the engine is really queit.
I don't remember it ever driving so nice, I actually have to re-adjust to shifting (mt).it must of been a problem for awhile and never noticed it going.
on another note. .... 8 months ago i put a K&N filter on it......did it cause the mfc to fail????
Kuddos to whoever found this fix.. unbelievable
I saw your other post in the "knocking.." thread I posted in.
It's possible your Pathy might have some other issues. Mine had only the lean bank code all along and it has been running fine since then (that was in Sept or October).
There have been several people that I have read about using the Maxima MAF and I can't recall anyone having side effects of it.
As for the K&N, I removed mine and went back to stock paper filter. First, I noticed that the filter is REALLY close to the MAF sensor. Second, I talked with a mechanic that told me it's possible that the oil from the K&N harmed the sensor.
