Need Help/Opinion's
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
damn
Car: 1986 Nissan 720 z24, Automatic trans
PEZi720 wrote:you have the 34 right?
i get what you're saying but its synchronous... not progressive... progressives are the ones with different sized barrels... and technically on yours there is no primary or secondary... they work at the same time all the time (thus the name synchronous)
and yes... if both sides are synchronized properly it will run MUCH better... took me a while to dial in
I thought the barrel that has the electric choke and idle jet's and the barrel that open's before the other does made it the primary barrel? I was under the understanding every carburetor that had more than one barrel had a primary and secondary barrel.
dogred wrote:
Yeah lots of people try to return that type of FPR because they are never correct.
Yeah after buying it and reading alot of very unhappr reviews about it i decided to remove it and now my fuel pressure is correct. Im still going to get a better one and fuel pump but i got my all forged 383 camaro im finishing up right now instead.
Modified by damn at 1:50 AM 1/11/2010
Modified by damn at 1:51 AM 1/11/2010
turbojunker
Car: 79 510, 81 720, 72 510-RIP
damn wrote:I was under the understanding every carburetor that had more than one barrel had a primary and secondary barrel.
True on a progressive carburetor such as a Weber DGxx progressive models, but Webers such as the DCOE and IDx's do not.
damn
Mine is the Weber 34 DGEC so is it progressive?
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
damn wrote:Mine is the Weber 34 DGEC so is it progressive?
No its not. The progressive webbers carry different sizes of barrels example the 32/36. The 34/34 and 38/38 are not. They're synchronous.
PEZi
my 38 DGES is synchronous as well... has idle jets on both sides (thus the 2 screws on the baseplate) and both sides do the same thing at all times
Return to “Datsun 720”
