Tx-Sx-FS wrote:i had a problem like this on highway in my 89..if ur car is a manual transmission..the problem on my car was on the clutch pedal..there is a clip or something that holds these too pieces together..its like a sensor something for the clutch..anyways..that piece broke on my car and it killed the car...wouldnt start or anything..i simply put a bolt and nut through the two pieces holding them together...and it started right up...a simple check on that and might be a simple asnwer but might be soemthing different on ur car...good luck
thanks..your talking about the clutch switch. right? when you start the car you need to press on the clutch pedal...
i'm gonna check that..btw, how in the hell did you figure that one out....
