need help new to nissan. car won't start!!
jser
Car: your girlfriend!!
Tx-Sx-FS wrote:if its the alternator..the car wont die right away..it will run off the battery until the battery dies..so check the battery
i saw that in another post but yeah..i'm gonna pull alternator out and test it...
so NISTECH i can jump my see if it starts. and that would/might say the alternator...
Tx-Sx-FS
Car: S13 KA-T
i might need to replace my alternator too..the relay or fuse link that says 75A ALT keeps blowing..and thinking its the alternator relay..which is either bad alternator or wiring..im not sure..got any ideas?
NISTECH
Tx I think I already answered that question in another post of yours.
jser If your engine will turn over when turning the key with out jumping it the altenator is not your problem. You are having the problem where the engine turns over but does not start correct?
NISTECH
I'll just go ahead and merge this with your other thread. No need to start another thread on the same problem.
jser
alright...thanks
jser
yep, found out whats the problem and it none of the aboveoil pump drive shaft spindle. this connected to the dist so it threw out timing and can't start! damm!!
