One is Attached on a bolt right below the valve cover and the other one is attached to what I believe my temperature air sensor, and my ECU also says code 41 which is the sensor.
In this 2nd picture it looks like the air temp sensor might plug into an extra unused wire near the maf (highlighted in the green circle)
Is this correct? and where does the wire that connect near valve cover lead too?
