NEED HELP HERE
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
84nissanowner
OK I have a 1984 Nissan(Datsun) 720 with the 2.4. I have an oil leak from a part that I do not know what it is, and cant find any info on the web about. There is a tube coming out of the block behind the exhaust manifold that is leaking. I'm sure that it needs an O ring on it, but I need to know what it is to get the right parts. CAN SOMEONE PLS HELP ME OUT?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
:worthless:
84nissanowner
I don't know how to post pics on here
Rogue One
2022 Honda Pilot SE
How to post pictures using photobucket
how-to-post-pictures-using-photobucket-t521110.html
I like to use ImageShack. I find it quick and easy.
Using ImageShack to Post an Image on the Forum
1. Go to https://imageshack.com/‎
2. Click on the Browse button.
3. When the "Select file(s) to upload by imageshack.us” box pops up, navigate to where you stored your image. Then click on the image file.
4. Back on the ImageShack screen, click on the Upload Now button.
5. Once your image has been uploaded, scroll down to the "Forum Thumbnail" box below your image. (You will see a link displayed in that box. That’s the link you need to post clickable thumbnails of your image.)
6. Now you need to copy the link displayed in that box.
7. To do that, first click on the link to select it. Once the link is selected, press Ctrl-C to copy it.
8. Next go to your message here on the forum and paste that link by pressing Ctrl-V.
Note: Before pressing the Submit Reply button, you may want to preview the link you pasted in your message. You can do so by clicking on the Preview Post button below the message box.
84nissanowner
Image Thank you for the link. Here is the pick of the part I need to know about. this is the best pic I can get of it due to the exhaust manifold.
kdwiedmann
Car: 1995 Nissan Pickup XE
Rogue One: I'm trying everything you said but all I'm getting is the link itself copied instead of the picture. On Imageshack below my picture there is box's for link, direct, forum,alt, and html. I've tried the link and forum. What am I doing wrong?
Rogue One
2022 Honda Pilot SE
I'm on my tablet at work, so I'm gonna wing it. I post pictures from my laptop which runs Win 7 Ultimate.
Once you've uploaded the picture, you have multiple options that can be a bit confusing. You want the left-hand column. Left click once on the down arrow next to the tag line that's second from the bottom. This will automatically copy the necessary info that you will paste onto your post. It will have the necessary formating tags, so you won't need to add them.
kdwiedmann
Thanks Rogue, I figured it out. Thanks for the help.
84nissanowner
so no thoughts on what this part may be?
xsdg
Car: 1985 Datsun 720
I'm guessing that's the origin of the hose that connects to the PCV valve over on the driver-side of the intake manifold.
The 510 has a different motor, but I'm guessing the layout is similar:
http://community.ratsun.net/topic/56764 ... s-install/
Return to “Datsun 720”
