Need help! clutch bleed
Kushpushk
Car: 1993 Nissan 300zx n/a
2 Seater
I just installed the z1 performance 6 puck clutch in my 93 na, did the clutch and pressure plate. my problem is ive bled the slave and no more air seems to be come out. and the petalwont build pressure it is also stuck to the floor and there is only a one inch of petal to pump the rest is nothing ? i gotta have this done by saturday and im in need of asistance
Thanks, Ryan
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
first of all you shouldn't have opened hydraulic's, you shoudl have unbolted the slave fomr the trans and not lost any fluid or introduced any iar, but apparently you did so....
when you bled the clutch, did you belld the remote bleeder ont he passanger fender as well as the one at the slave? if not, go do that, if so, you ahve a bad master or slave ro both, they should be replaced as a pair, sometimes old hydraulic seals can't handle the additional pressure of a new heavier pressure plate
Kushpushk
2 Seater
thanks i ended up finding this at work clutch-slave-cylinder-t242530.html yeah i didnt know about the second bleeder. and i had to break the hydrolic line to replace the slave cylinder while doing the clutch
evildky
06 Nissan 350Z GT
you didn't have to replace the slave...unless it was bad
you said this started after ahanging the clutch not the slave, chances are the master won't be far behind it
Kushpushk
2 Seater
I just always heard it was good thought to replace the slave when you did the clutch. Well the petal is good now that i bled it, but i belive i had some installation issues because the clutch is not disengageing, i belive i have a problem with the clutch fork, so tomorrow im going to tear it back down.
evildky
06 Nissan 350Z GT
pedal not petal (hint: a petal is a part of a flower)
it's never a bad idea to replace old parts but generally the slave and master get replaced at the same time
as for your release issue, when you say it won't release this means you can't get the car in gear when running? or you mean you just slip the clutch? sometimes it helps after bleeding, to do one last bleed where you crack the valve at the slave while compressing the piston, then close the bleader and the pedal will self adjust the slave
Kushpushk
2 Seater
The pedal is firm, yet when the car is running, you cant get her in gear. Thanks for the spelling corrections, although you got the point.
evildky
06 Nissan 350Z GT
pedal height adjusted properly?
Oh Em Zee
Car: '96 Nissan Z32 Slicktop
'90 Nissan Z32 2+2
make sure the pedal is adjusted properly for clearance before you have to disassemble everything.
i dont remember specs but it was in the FSM
