there are 2 bleeder valves on the Z32, the 2nd one being on the passseger side of the engine bay, next to the fender. i would HIGHLY recommend speed bleeders, it makes it oh so much easier. check out splparts.comevildky wrote:if it's leaking out of the slave then yeah you need a new slave, not a bad idea to replace the master at the same time, also you have to bleed the system after, pretty much the same as brakes but you have only 1 bleeder and it's on the slave
