guillermoe wrote:
Thanks for the info Now I have one more question for you.
From what I am learning about turbos I can remember that total power is created by the quantity of air reaching the engine, the A/F ratio and some weird thing called bsfc (sp?). The air flow is created by the quantity of pressurised air existing in the system... the more the pressure more air flows when released right? If this is true, how is it I need to change the boost settings when using different trim turbos to achieve the same power goal? I thought the boost needed for... lets say 300 HP in a KADE... would be always the same... no matter the turbo being used. Hope you could clarifying this to me n00b
More pressure only works if the density of the air remains the same. As air gets hotter, it is less dense for a given amount of pressure. In other words, hotter air at the same pressure has less air mass (molecules). There are two major components to making power with a turbo aside from the obvious, which is boost pressure. Efficiency is key.
Based on the operating range where you want the most power, you choose a turbo that best fits along with the necessary boost level you would need to reach your power goal. The efficiency shown in a compressor map has a direct relationship with how aerodynamic the innards of the compressor is under the given parameters (boost and airflow). Better aerodynamics means the turbo heats the air less as it pressurizes it and the less turbine shaft torque is needed to spin the turbo to obtain the desired pressure and flow. For best results in the desired operating range, choose a compressor to match that operating range and then choose a turbine that is most efficient at around the same range. T3/T4's do not fit this description. They are a compromised design where some of the top end turbine efficiency is traded off for the ability to spool up a larger compressor wheel at a lower RPM. It's not a terrible trade off by any means, but depending on your goals, if you want better upper range HP, then a T3/T4 may not be the best choice.
The other side of this is also turbine efficiency. While this is a bit more difficult to plan for, it is important to consider how efficiently a turbine can convert the heat and pressure into mechanical energy. Less efficient turbines will require more pressure and/or heat to spin a given compressor. This generally means you will have more backpressure in order to achieve the pressure differential across the turbine that you need.
Most people will tell yoou that bigger turbos are more efficient. DO NOT follow this rule of thumb. Bigger turbos do generally allow for more power, but even that notion can lead one to a poorly chosen turbo. Most motors can work quite well with a large variety of turbos, but the operating range of the turbo and motor need to be matched for best results.
Large compressors do not handle low airflow conditions as efficiently as smaller turbos. For example, if you had a motor that flowed about 15 lbs/min maximum at 9 psi, and you tried to apply even the touted T04E 50 trim compressor, you'ld barely reach the 74% efficiency island at redline and be below that number at any other RPm below redline. Since you won't reach the 78% efficiency island that turbo offers with such a motor, the peak efficiency won't make any difference. Not to mention that the turbine will probably be way out of efficiency for the amount of airflow going through it. Add to that the larger sized wheels and it will be a slow spooling inefficient turbo.
But, if you look at a T3 46 Trim, you'll find that the peak efficiency island occurs before 15 lbs/min at 9 psi while getting close to the 70% mark at redline. Much of the engine's operation will have crossed through the 74% efficncy island. With smaller wheels, there will be less mass to move and the turbine will likely be operating efficiently where the engine will be seeing boost. The bigger is more efficient theory doesn't work here.
As for which turbo is the best match, the last one shows you are maximizing the use of the peak efficiency island. This would likely give you the most overall power (average power across the powerband). Understand that peak power is not as important as overall power.
