Ok, there is something I dont understand well.
C-Kwik wrote:Boost threshold is the engine RPM where you reach the set boost level at full throttle.
By this I understand the BT is the instant when spooling is finished, we run at full boost and the wastegate starts working. Right?
If this is true, please explain me what you mean by this:
C-Kwik wrote:This will vary with RPM and unless you're over the boost threshold, there will not be any boost response.
How can we be in a point over the boost threshold if spooling hasnt finished, or even started, yet?
On the other hand, I understand choosing the correct turbo is the key for making your car behave as you would like. My question on the light flywheel and underdriven cranks was just to know it there would be any gain in using them. I already bought a gt28 with housing options focusing on response but, once finished, would like to test some extra options for increasing response. This is my first turbo project so I want to learn all the possibilities.
