Killer B Racing »
https://forums.nicoclub.com/killer-b-racing-u136219.html
Tue Sep 22, 2009 5:44 pm
Hi,
I'm building a 95 s14 for stock car racing on a high banked 3/8 mile asphalt track. I'll need to squeeze about 190hp to be competative.I've had great success with my stock s13 KA24e stock car but if i'm going move up to the pro4's I'll need to get more power. I just keep finding turbo's and related parts.Hopfully someone has some none turbo/nos info available.I have included the track rules .
thanks!!
1. Stock OEM for year and model of car used. Maximum 2500 cc engines. NO turbo engines orsuper charged engines allowed. Only 4 cylinder engines allowed. No dual plug cylinder headsallowed. ALL ENGINE PARTS MUST BE STOCK OEM. All engine parts including stockreplacement parts or aftermarket parts where allowed MUST maintain stock OEM weight andspecs and must be COMPLETELY STOCK UNALTERED. This means NO boring, stroking,porting, polishing, lightening, deflashing, glass bending, sandblasting, abrasive cleaning, chemical(acid) milling, etc allowed anywhere in or on engine parts. No internal painting or coatings (i.e.Teflon) of any type allowed. No engine balancing. 2.3 Ford single over head cam two valves percylinder only one spark plus per cylinder max over bore .040 maximum flat top or OEM dishpiston only normal OEM type engine balancing. Bore and balancing allowed ONLY on the 2.3Ford engine.2. Location: Must remain in stock position.3. Compression: Maximum compression is 9.5:1 checked with the “whistler”. No tolerance allowedon maximum compression.4. Crankshaft: Must be stock OEM, maintain stock stroke. No lightening or knife edging allowed.5. Pistons: Must be stock OEM or exact replacement.6. Rods: Stock OEM Only. Aftermarket rod bolts allowed.7. Camshaft: Aftermarket camshaft allowed. The maximum lift at the valve with zero lash willbe .465”.8. Rockers / Followers: Stock OEM only. No roller rockers / roller tips even if stock OEM! Stockratio for engine used, rocker studs may be oversized.9. Valve Lifters: Must be solid only. No roller lifters if stock OEM.10. Cylinder Head: Stock OEM production head only.11. Valves: Must be stock OEM or direct replacement only. No pro flo or polished valves allowed.Aftermarket stock diameter valve springs allowed. Steel valve spring retainers only.12. Valve Job: Multi angle valve job permitted. The bottom cut of the valve job may not exceed3/8” in to the valve pocket. The 3/8” bottom cut will be measured from the top of the cut uponwhich the valve is seated.13. Intake Manifold: Must be completely stock and unaltered.14. Carburetor: The Holley 350 CFM, 2 BBL carburetor part # 0-7448 is the only carburetor allowed.The carburetor must be “stock out of the box”. All carburetors must pass NASCAR gauges.The only changes that will be allowed are as follows: the choke plate and shaft may beremoved, jets, power valve, accelerator pump cam and accelerator pump discharge nozzlesmay be changed. Idle holes may be drilled in the butterflies. No other changes allowed. Noreshaping, polishing, grinding or drilling allowed. No adjustable (jetted) air bleeds or circuits.Gaskets must remain unaltered. No “HP” parts allowed. No chrome carburetors.15. Carburetor Spacer / Adaptor: One solid material spacer / adapter, maximum height of 1”permitted. No wedge shape spacers / adapters allowed. Both the top and bottom surfaces must beparallel. The porthole may not be tampered to meet the stock intake opening. No additionalopening for the induction of air allowed. Only one .075” gasket per side of spacer allowed.16. Fuel Injection: Must be stock for the year, make and model of car being used (strictlyenforced). Fuel pressure is not to exceed 45 PSI. This will be strictly enforced.17. Air Cleaner / Filter: The air cleaner top and bottom must be metal. All air cleaners are subject totrack approval. No ducts, baffles or anything that may control airflow allowed on or in the aircleaner assembly. All air entering the carburetor must pass thru the air filter. No air boxes. Ashield may be used on the front outer half of the element if placed directly on the element. Aircleaners must remain under the hood and made of paper.Holland Motorsports Complex 2009 General Information and Pro Four Rules 2118. Fuel: Must be petroleum based or synthetic automotive gasoline only. Gasoline shall not beblended with alcohol, ethers or other oxygenates propylene oxide, aniline or its derivatives,nitro compounds or nitrogen containing compounds. No additives that enhance horsepower.The use of stock unleaded fuel sold at local gasoline station is allowed. Fuel will be tested.19. Fuel Pump: Electric fuel pump allowed but must be enclosed in a steel box under the car.Fuel pump must be as close to the fuel cell as possible. The fuel pump must be tied in withthe oil pressure switch, no oil – no fuel.20. Exhaust Manifold: Stock OEM only. No modifications allowed. No headers allowed.Maximum outside diameter of the exhaust pipe will be 2-1/2”. Exhaust must exit 6” past thedriver’s seat, under the car.21. Mufflers: Mandatory! Max 2.5 inlet and outlet.22. Oil Coolers: Not permitted.23. Ignition: Stock OEM.24. Computers: Computers must be stock OEM and only for the make, year and model. No crossingof makes and models. No altering on board computers or electric control units (ECU).
