dimedriver wrote:If/when you get it chipped get the tunner or dyno shop to make it a totally open loop system on AFR. Loose the O2 sensor and run the 110 leaded gas. I guess you could leave it in the exhaust stream and hooked up but the ECU will not do anything with the data. The lead is going to kill it anyway.
Whats the highest anyone has revved a KA for long periods? Not a down shift to 3rd at 60mph or anything like that.
liquid, do you have a dyno sheet from your cam? What is your redline set at now?
-Avery
i have no dynosheet..im broke..that cost money at this time...but i regularly rev past 7000rpm with no worries..my powerband sits between 4500 and 6500...1st and 2nd are qwick gears for me but she opens up at 3 -5th..with my limiters off...
i um..participated in a kinda road test against a supra last night down St.Rose Pkwy here in vegas..i held my 7000rpm limit in 4th just for kiks for probly 3 mins with no adverse effects on the engine other than heat..BTW..he backed down from our challenge..lol. if i had more numbers for you, i would gladly give em up..but till then..i hope this helped a little bit.
