Need Help Asap
sr kid 88
Car: 91' sr240
ok i just had my motor rebuilt, my mods are cp pistons, darton sleeves, cosworth head gasket, bc valve train, titek adjustable cam gears bc stage 3 272, greddy intake manifold, tomie big bore throttle body, emanage ultimate for tuning. my problem is the shop where my car is at can't figure out the problem. it starts and is smoking white constantly my wideband reads 10-11 air fuel ratio. they have to fix my air fuel ratio fast before it washes my piston rings out again.they would pull fuel out on the emanage to about 14-1 but it goes back to the 10-11 on the gauge. the emange connectos are connected fully and i don't have a clue. anybody have any ideas what the problem could be.
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
Ugh did this same shop build your engine? And are they letting it go into closed loop mode before they try tuning it? Is it throwing any codes?
sr kid 88
Car: 91' sr240
yeah the same shop built it and i don't know if it is throwing any codes or is in closed loop
sr kid 88
Car: 91' sr240
update.. went by the shop and the wideband is reading mid 14's for air fuel ratio with rough idle and car doesn't respond when the gas is pressed untill a couple pumps. and ideas?
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Sounds like timing is off.
I dont know why they are so worried about washing the rings, I've run 10 A/F R at idle on cars plenty of times. They should be more worried about the white smoke.
What shop are you working with?
sr kid 88
Car: 91' sr240
the car shop killeen texas. what would be your guess on the white smoke
sr kid 88
Car: 91' sr240
now car smokes white when wideband reads rich?
