nice to see someone who usually doesn't take time to make posts helping out...Bongpain wrote:ok thats good. no coolant in oil. as far as black oil go its. normal. why because the guy that had that motor before you may not have change his oil often and on time. so if you get this car running change your oil in like 1500 miles interval for like 4 oil change you will see the different. or you can buy oil clean additive and follow that instruction do it a couple of time and you will be good. black oil dose NOT indicate head gasket problem. a lump on the gasket will cause coolant leak. replace it. and make sure you use an emory cloth or realy fine sand paper to clean out the old coolant. then re-install. and if it still leak you can also get a coolant pressure tester at a part store or tool store and this will 98% of the time pin point your leak/s.
pretty sure i told you to check the head gasket.... DON'T DRIVE IT TIL YOU REPLACE IT... You're killing your compression...newyork910 wrote:ok i understand what you guys are saying.....and bongpain i did find the leak i just found it now n it doesnt look good its coming from the block and the head near the intake man... am not sure what to really think what it is my friend with me said its the head gasket maybe when we put the head gasket on it moved the when putting the head on casue thats where the leak is coming from its not the water pump its coming from the block and in between the head in one spot like i said near the intake man so what could that be???am hoping its just the head gasket so anything come to mind????plz gave me good news lol
You shouldn't have a dent in your head... As far as the gasket change it... the only big problem you could have is the head being warped... Did you purchase the engine from a junkyard or a private person? If you got it from a junkyard, there's a decent chance you can tell them what's wrong and them give you a refund or at least a replacement... Private person... You're usually pretty much on your own, especially considering they most likely knew this was wrong...newyork910 wrote:i know you told me so lol...damn i just was hoping it wasnt that..but am not driving it i already started taking everything off to get to it now..but i have question what if i have a like a lil dent or something between there what could i do to fix it beside sending it to a shop cause i dont have the money for that right now???
If it's a good friend, I doubt he intentionally sold you a messed up engine. I'd say your head gasket just isn't seated well... Still, check the head as an in-case thing though.newyork910 wrote:no i got it from a friend of mine that got in car crash n couldnt drive it anymore i guess am going to have to check to see if the head is messed up or not...
http://www.photobucket.com to upload your photos...newyork910 wrote:i have another question does the head gasket have the same amount of holes that the block has????because i seen that the gasket has less holes on it then the block...i would put some pics to see you guys but not sure how to tho... am bout to put everything back together and see what happens from there...
