NEED HELP AGAIN???COOLANT FROM THE OIL PAN???
Bongpain
Car: 92 240sx
carkook is right the head may have many more holes. the head gasket will have part that is blocked off and would only allow certain hole for coolant to past through. as long as all the head bolt are lined up you ok. and if am not mistaken you CAN'T reuse a head gasket. once it is crushed you will need to replace it. just don't forget. put extra rtv on where the head gasket meat the block at the front cover. that sound like the spot you said the leak was coming from.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
carkook wrote:No the headgasket does not have as many holes as the block, its just the way its designed. And if you drained your oil and there was no coolant in your oil the headgasket is FINE. This sounds like an external leak somewhere and its just running down your engine. You said you replaced a bunch of hoses my bet is that you didnt tighten one up all the way or something.
Your 2nd statement is incorrect... I've seen engines with bad head gaskets never get coolant into the oil...
Bongpain
Car: 92 240sx
pyroniak is correct you can have a bad head gasket with out coolant mixing into the oil. i may have leak on to the outside. not all head gasket leak mix oil.
carkook
Yes you guys are right, thats in a general statement. OBVIOUSLY you can have a bad headgasket with out coolant getting into your oil.
But in this case, he has an external leak of coolant. There are NO coolant passages where the headgasket is located that would cause a leak where he has a leak(Near the oil pan). So the leaking is not from the headgasket.
Come on now use your brain smart a**.
PyR0NiAk
newyork910 wrote:ok i understand what you guys are saying.....and bongpain i did find the leak i just found it now n it doesnt look good its coming from the block and the head near the intake man... am not sure what to really think what it is my friend with me said its the head gasket maybe when we put the head gasket on it moved the when putting the head on casue thats where the leak is coming from its not the water pump its coming from the block and in between the head in one spot like i said near the intake man so what could that be???am hoping its just the head gasket so anything come to mind????plz gave me good news lol
carkook
Missed that part, sound more like the intake manifold gasket where the coolant runs from the head into the manifold.
ZakinaS13
Car: 90 S13 w/ 98KADE
Did you have a previous bad timing chain? If the timing chain goes without being changed, it will wear a hole in the water port of the timing cover. Try taking the timing cover off and look to see if theres a hole in the water port. You should see rub marks on the inside-left of the cover.
