NC SC CHAT
Including AR, LA, MS, AL, FL, GA, SC, and NC
typeZEROs14
Car: 1995 240sx
they might not b open yet.. but i donno..ill go check 2mrw
theirs an Import shop called 1320right up the street from that one..they do tha typical import stuff.
maxima278
Car: 96 240SX SR20, 69 Ford Pickup, 99 Dodge Ram 1500, 1996 Nissan Maxima, 1997 Nissan Maxima project, 89 Coupe shell
how come there's 2 guys on here with the same S14 in their sig? just curious.
You need to get the ends that meet up to your compressor altered. Beyond that I don't know about the wiring, I guess it should just work.
typeZEROs14
Car: 1995 240sx
240DRifte7 is typeZEROs14
I just created a new account to signify my project nameyeah yeah kinda dumb but who cares
im just trying to up my post count on typeZERO now
scs13
Car: 93 s13 coupe
zee, ill swap your motor for you for CHEAP. if you get a front clip its super easy and even quicker, dont have to search for parts and all that nonsense. the sr we swapped only took about a day.
a shop just opened up off of wade hampton in greenville. they are supposed to be doing a dyno day every month. 35 dollars for three pulls. theyre pretty cool too, like you said they said it was cool for people to hang out in the parking lot as long as nobody acts like a jackass.
greg, you should check under the valve cover for the upper timing chain guide. it was like a factory recall or something to have them taken off. they break and rattle around and stuff. it should be right on top of the timing chain, two bolts and it comes off. hopefully thats all it is and nothing serious.
oh yeah and pat, i removed all that bs off my motor, but ill check my brothers car tomorrow for you. they should have colors on them though that tell you where they go. you could always look at the FSM and it will tell you too.
gnvarnadore
Car: 89 240sx Base Coupe(daily/project) 91 240sx SE Coupe(sold) 92 240sx SE Coupe(sold) 89 240sx Base Hatch(sold) 93 240sx SE Hatch(SOLD!!!)
scs13 wrote: greg, you should check under the valve cover for the upper timing chain guide. it was like a factory recall or something to have them taken off. they break and rattle around and stuff. it should be right on top of the timing chain, two bolts and it comes off. hopefully thats all it is and nothing serious.
cool ill check it out sometime this week
Zee
Car: 99 Chevy Cavalier
scs13 wrote:zee, ill swap your motor for you for CHEAP. if you get a front clip its super easy and even quicker, dont have to search for parts and all that nonsense. the sr we swapped only took about a day.
Thanks, but I won't have the parts till the end of the year and I not getting a clip I am getting an engine set from Heavy Throttle and the swap package with everything and a turbo timer and stuff, but when the engine gets pulled I want to paint it then so it will be a complete job, but I will get back to that when the time comes.
scs13
Car: 93 s13 coupe
getting the whole car painted or the engine bay. my brother paints too gotta try and get some work since i dont have a job at the moment.
Zee
scs13 wrote:getting the whole car painted or the engine bay. my brother paints too gotta try and get some work since i dont have a job at the moment.
I am going to get everything painted car and engine bay, but if you have some pics of your brothers work i will defiantly consider him for the job but this is going to be very involved and is not going to be really simple and I am a tough critic.
Please remember I won't be doing till the end of the year at the earliest.
Modified by Zee at 2:07 PM 5/1/2007
gnvarnadore
Black on Gold wrote:
X= 5 11/16Y=3 5/8
i measured it with the hood pins in, so its dead center on the hood pins.
Black on Gold
Thanks Gregg. Hood is done so all thats left is pick it up from school. I just hope the those leaks are whats causing my car to run like ****.
kouki munster
Car: 97 base 240
Pat, cap off all of thoes hard lines under the throttle body that are open.
I finaly got my Z back on the road , but I have 473(ish) miles until I can start having some fun with it.
I'll get some pic of it posted up of it in the next few days.
Black on Gold
Are you sure? I've many times, capped off that one long line that im unaware of and the car shuts off.
kouki munster
Car: 97 base 240
All the hard lines that are open in the pics under the tb need to be capped.
Black on Gold wrote:Are you sure? I've many times, capped off that one long line that im unaware of and the car shuts off.
The long one that goes across the radiator? If so try hooking it up somewere between the maf and tb. I'll have to look at one of my 240s to be sure but it can't hurt to try it. I'll try to get some pics of how I have everything hooked up to.
Black on Gold
Well its the third hardline on the TB.
I know the middle one goes to the Charcoal Canister and im sure the other two do too?
maxima278
that's awesome Turstin, so when are you bringing it down here?
Also, anyone here know anything about frontends? alignments and such?
Black on Gold
Yea i know a bit about alignments. what you need to know?
maxima278
what would cause negative camber on the front of an S14? What would cause the steering wheel to want to stay in whatever position you point it in?
Black on Gold
Either its been in an accident,hitting excessive holes in the road, had control arm or anything like that changed. It could also be that the bolt that you use to adjust the camber is loose. All those would be a factor
gnvarnadore
maxima278 wrote:what would cause negative camber on the front of an S14? What would cause the steering wheel to want to stay in whatever position you point it in?
ok i know this might sound dumb but are you sure it has negative camber because if your going by the way the tires look depending on driving habits it can cause tires to wear abnormaly, also if it is negative camber how bad is it because negative camber isnt a bad thing, if at the right angle it can improve handling. could be something is bent or broken under the car if your refering to the car you just got, and as for the steering wheel you got me on that but i would check out the whole steering column and rack to see if its broken somewhere or if something is loose and if its properly lubed.
scs13
Car: 93 s13 coupe
straight from the fsm. you probobly shouldnt cap those off because im sure the PAIR system needs vacuum. if you think you have a vacuum leak then spray some starting fluid over all the vacuum lines in the engine bay, that will tell you where it is. the engine will idle up whenever you spray it in a spot where there is a leak. i dont really see that this has to do with your car running rich though. if you have a vacuum leak your car will run like **** and you will have an unstable idle.
maxima278
Black on Gold wrote:Either its been in an accident,hitting excessive holes in the road, had control arm or anything like that changed. It could also be that the bolt that you use to adjust the camber is loose. All those would be a factor
the last guy hit a curb with it. Hard enough to blow the airbags. I've taken the wheels off the front, and the only thing I see is a tension rod mount that is a little mangled and what looks like the wrong nut on a tie rod (tie rod has been replaced on the right side). I was expecting to find bent or broken parts, replace them and press on. But I'm a little stumped.
I'm sure an alignment shop could fix most issues with the camber, but I just don't know about the sticky steering.
kouki munster
Car: 97 base 240
The PAIRC system does nothing but let fresh air to the cat so it will start to work faster, if your a tree hugger keep it, if not ditch the waste of space (and plug the associated vac. lines) and enjoy the extra room you have in your now cleaner looking engine bay.
maxima278 wrote:that's awesome Turstin, so when are you bringing it down here?
I will more than likely be heading to atlanta to look at that parts car you found on craigs list on thursday so I should be able to stop by and hang out for a little while and help you figure out whats wrong with that s14.
scs13
Car: 93 s13 coupe
you cant get rid of the entire pair system unless you plug or weld the hole closed on the downpipe. ive gotten rid of all of the emissions off of my motor, egr, secondary butterflys in the manifold, swirl control valve, pair, charcoal, the nest of doom behind the motor. only vacuum i have is the fuel pressure regulator and the brake booster.
i think he might as well do the carb cleaner because just removing those vacuum hoses isnt getting rid of half of the vacuum bull**** in there. but yeah i guess i would just get rid of the pair valve (i had no idea what it was supposed to do) and the charcoal cannister too.
ill post some pics of my engine bay tomorrow to show what ive been up to
is there any way to get around the maf making your car run like **** if its too close to the tb.?
Black on Gold
Would capping off those lines, fix the running rich problem? or atleast help? If not then im thinking about just swapping in a new KA.
What you guys think about the 92' KA?Is it hard to change the bearing? What should i offer him...?http://www.carolinanissans.com...10732
scs13
Car: 93 s13 coupe
if youre gonna swap in a new one gimme your old one.
The Duke
Car: 1989 nissan 240sx fastback
You need to post those pics jordan. Does anybody know where to get the best deal on a pignose lip?
scs13
Car: 93 s13 coupe
idk if i told you, but i know where you can get one for like 50 bucks. oh yeah, and hopefully we will be turboing devons car this weekend. depends on if he gets all his parts or not. it should be a beast though
Black on Gold
Tell me where to get a Piggy lip for that cheap. Im looking for one to put on the Chuki
kouki munster
Car: 97 base 240
I have pictures!!!!
Modified by Beatupsx at 11:40 PM 5/2/2007
Modified by Beatupsx at 12:04 AM 5/3/2007
scs13
Car: 93 s13 coupe
throw some paint on that b1tch! and itll be dead sexy.
anybody know somebody selling coilovers for a decent price, im in desperate need of some.
Return to “Southeast Region”
