Naloo10's S13 drift project thread...56k? mmm def not
jspec603
Car: 92 verrrrrrrrrrrrrrrrrrrrrrrrrrrrrrt
Naloos13 wrote: What color are you thinking of?
I keep tossing a few colors around in my head. Lately I've been sticking to the off white that comes on the 300M and other dodge products. There are others out there that I like as well, so we will see. I'd like to see the car in person sometime, check it out. Maybe Dan and I could swing by, eh Dan?
Naloos13
Car: 1989 S13
Ya, i am planning on working on the motor more this weekend. Early saturday. I want to clean all the pistons, install the new piston rings and install the valve springs, and i should be happy for now. I want to get it back together asap, but i have to wait for the rod and main bearings as well as the front and rear main seal to get here.... lame.
Ya, the two of you can def stop by sometime, but, not this weekend. ha. Im hoping to finish all that by like 10:30 or 11 am, then i have to head down to connecticut to pick up another sr! not for me, to install in a friends car.
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
Nice shop, very roomy. That shell looks clean, you got a good deal on it. I would it kept the bumper and trash the rear valences... Project is looking good.
DJButton
Car: 2010 Nissan 240sx
With the way I hacked molded those rear valances on it was probably easier to leave them be.
Yeah, I'd love to stop by and check it out at some point, let us know when a good time is!
Ilvemynissan
Car: 240sx s13
I'm sorry but can someone please fill me in ....i am always seeing these new builds/projects with somthing about a 56k.....please explain 56k
amolao
Naloos13
Car: 1989 S13
ya, the bumper was def a no go. Way too rice and broken. And the rear valences..... well those would have been too much work to take off. I am planning on buying a full kit in feb that will replace them as well as the bumper. That was always the plan so i decided not to waste my time. Plus i had no idea what was behind them. Nor did i want to find out based on the rust repair that i have done.
Jyon9689
Car: 1991 240sx SE
Nice paint bro, build's looking fly
Ilvemynissan wrote:I'm sorry but can someone please fill me in ....i am always seeing these new builds/projects with somthing about a 56k.....please explain 56k
It mean's theres a lot of (possibly hi-res) pictures. If you rock the dial-up modem, you live in fear of such a thing
DJButton
Yeah, the rust was what made me sell in the first place, the frame kinda scared me. Being one who is scared by most body work and repair of that sort you'll understand why I spent 2k just to get a clean S13 chassis. Any thoughts one what kind of kit you want for it?
Naloos13
Car: 1989 S13
Well the wheels along with the body kit all depend on whether or not a get a different job. Which will hopefully happen asap. So, ideally i would like to get the BN Sports Type 4, which you might recongnize happens to be Fukuda's kit..mmm im just gonna take a moment to envy his car...450whp sr.....ok so ya, thats the kit i want, i just need the funds. As for wheels i havent decided yet. Ideally i want 18's. However, i basically have an unlimited supply of low-pro 17's (falkens, pirelli's, BFG, and michellines). So i cant really justify buying 18's when i wouldnt have to pay a dime for any 17" tires. So id like to find some 17x9 F 17x10.5 R. Im still tossing around some wheels. I cant decide if i want chrome, or if i want black, or white, or some other color. We shall see. Feel free to drop some idea's off. Im hoping as far as HP numbers to hit 400 at the wheeland mayyyyybe like 430ish. I dont really see why i wouldnt with the cams, turbo, fuel system, engine internals, and power fc d jetro.
DJButton
Man Dousan's car is so ill^ Love his new rear wheels, maybe he'll find matching fronts at some point. Nothing wrong with 17's especially if you can get good tires for cheap! I'd say 17X9.5 f and 10.5r with a +15 all around would be nice with a little camber and a roll maybe slight pull too depending on tire size, just my two cents. For my own car I want a pair of 18X10's front and 18X12's prefferably rear... yeah I know lots of work needed to fit the front. Your power goal I would agree on, should be easily reached, that'll be a heck of a good time!
ajones1229
Car: 1990 240SX KA24E
May I suggest hyper black for your will color?? a black gloss wouldn't look bad at all. Just me .02
Jake's coupe
Car: 1991 240sx coupe R.I.P. New 90 240sx coupe
Looking good conpard to what it was, can't wait to see it on some summer drives.
Naloos13
Car: 1989 S13
Sorry it took so long for an update. Between Work, school, my gf's birthday, our anniversary, valentines day, and doing an SR install, unfortunately my motor has taken a backseat. Anyway, i started out by scrubbing, then pressure washing my block and getting it all nice and clean.Then i carefully scraped off all the head gasket material and cleaned the head surface as well as i could.It was at this point that i went to remove all the oil jets. And magically broke one without even touching it. No joke. SO! if you have one please let me know so i can buy it from you. lol. Anyway, here is my cylinder walls. They were actually in very good shape. You can still see the crosshatch in each cylinder. However, i had an identical small wear spot on every cylinder in the same place which is shown.Anyway, enough of that. I then used my deglazer and re-cross hatched each cylinder and here are the results.So got all my rod and main bearings in the other day, as well as the front and rear main seals. so i was planning on installing everything this weekend. But, i guess i have to find a oil jet before i can do that one. So i started working on the head. I removed all the valve springs etc. and cleaned each valve. And also lapped all of the valves.http://s55.photobucket.com/alb...4.jpgLastly, i havent taken the pictures yet, but i have replaced all the valve springs w/ the BC Titanium ones which are night and day beefier than stock. So next update will be....as soon as i find an oil jet.....so if you have one let me know!!!
crazy240kid
Car: white 90' 240sx hatch, Blue 89' 240sx hatch
Nice build, love the wheels and the paint. Keep up the good work.
DJButton
Lookin good man!
otto_3478s
Car: 94 AlTiMa + 94 tT 300 zX
+1 for best paint scheme evarrrr!!11!!!!!!!!1!!! Seriously I LOVE the panda theme. Keep up the good work man!
meglinton
Car: 2011 G37 Sedan
Not to jack the thread or jump back too much, but where did you pick up the SR in CT? Been looking for one myself, and would love a local-ish reputable engine importer/distributor...
Naloos13
Car: 1989 S13
Ha...ya...about the motor in CT....well a customer of mine, wanted me to pick it up for him, its not for me. He traded his 91 hatch for sr to some kid in a wicked sketchy area...Sorry, no local motors that i know of.
DJButton
CIP can get you SR's hit up http://www.240sxmotoring.com to check them out!
Roldy
This build is gonna be sick.
Naloos13
Car: 1989 S13
Good news! i found the oil jet/squirter at phase2 for $50....better news is i bought one off someone here on nico for $25 shipped! maybe i will have it by friday???
Juanit0
Car: 1993 Silvia Vert
good work!
TRBOMOFO
Car: S13.5 built redtop
awesome detials love the build
meglinton
Car: 2011 G37 Sedan
quick threadjack (GOD I hate people who do that...)/
I had already hit up Jeff @ CIP in January, they aren't importing/distributing SR's anymore - he said that they "can not get the motor." Any other local places? New England or Tri-state area?
/end threadjack
By the way, love the build, those rear wheels are tight , keep it up!
Asmar
Car: 1994 Nissan Skyline
Lookin' good bro, lookin' good.
Naloos13
Car: 1989 S13
Thanks for the all the compliments and advice guys. As far as finding an SR...best idea for semi local would be to take a ride up to canada...its only a 3.5 hour ride for me. Too bad too, because i passed one up in mass for $350 a few months back. (obv w/o a transmission and needing some work)
So basically i finally got the oil squirter in the mail. I went to frsport and thought i had bought a full bearing set.....nope...just but 1 bearing...I wasnt to happy bout that specially since i paid through the nose to get it shipped express. So much for that...plus its not worth returning. So if anyone needs one grade 2 rod bearing and onegrade 2 main bearing ill hook you up with a sweet deal. So i went ahead and ordered a set of the Cosworth racing rod and main bearings for the motor....I called and made sure it was a full set.
It feels so weird having my car all ripped apart. I went and sold my sparco seat today. And i think im gonna pick up this signal auto seat. Anyone heard anything about it?I mainly just wanted something more agressive. I was going to pick up the Bride Zeta 3 seat, but the price difference is basically a no brainer. Anyway, talk to you soon hopefully. I am looking for a new DD cuz im sick of driving around a POS in the winter, and not having AC in the summer. So it might be a while before i finish the 13 because of $$$$$$$$ <-- the necessary evil.
F7Flare
Car: s13 sr20det
damn i wanted that sparco seat! haha
to meglinton - check this link theres an sr20det for 1500http://hartford.craigslist.org/pts/541710768.html
the signal auto seat looks nice
i should have thought about having my own build thread
Naloos13
Car: 1989 S13
where you located in nashua? I actually sold the seat to someone in nashua
F7Flare
Car: s13 sr20det
are you serious Naloo
i have the same username as my screennamei bought your sparco, lol
