New Jersey »
https://forums.nicoclub.com/new-jersey-u172630.html
Sat Apr 16, 2011 1:29 pm
from that link:
9. The heads are different between NA and TT. The castings are almost the same but not quite.
The intake and exhaust runners are of a different design in the turbo heads. The castings offer a
more open port for the TT. We have used them interchangeably before without any problems, just
probably results in the loss of some power, when using NA heads on a TT. It is significant enough
that it would take extensive porting to get NA heads up to TT specs. We use different spark plugs
on the NA and TT but we see them used backwards and every way in between a lot. The TT ones
we use are NGK PFR6B-11B which are slightly longer that the NA PFR6G-11. The longer plug is
“colder” which helps with preventing detonation at higher boost levels.
to me, thats no big deal. im shooting for around 400whp, but would be happy with 380whp. i just want a fresh build, great low end/powerband, and newer parts for reliability. used motors and turbos are not an option for me and teh differences between na motor and tt dont seem to matter much to me.
thanks for the headsup though. i'd actually already read through that, but i guess i dismissed it due to Z1s attitude towards the differences.
