To continue from Part 1...
Once the brakes were upgraded, I got the itch to give them something to stop. Since I was tired of being the slowest in the family, it was time for a radical change. I found a Z on TT.net in Colorado. The car was immaculate until a domino's pizza delivery guy slammed into it and totalled it. The car had only 68k miles on it, turbos with only 10k on it, new timing belt and clutch. The guy parting it out also had upgraded Stillen Intercoolers, a JWT ECU, a new EFI wiring harness, but had sold the injectors. I bought everything I needed to do the conversion, plus a bunch of interior items, transmission, gauge cluster, shipped for a little over $3k.
My initial intention was to do only what was necessary to get the motor stable and reliable and do the conversion for under $5k. However, both that goal and the budget soon went over the side. I have a habit of doing that. I start small, but soon get excited and begin to upgrade. My son called it correctly when he said "It won't happen Dad, you will not settle with middle of the road stuff."
My initial list was:
120k kit
555cc injectors w/ boost jets (that was what the ECU was programmed for).
Stock TT bumper.
Turbo timer
TT fan clutch (didn't have one since his setup was electric)
TT shroud
The engine showed up from Colorado on a day when we had snow. I pulled it into the garage and began to inventory all of the stuff I received. I had everything I needed to do. But, when we converted my son's Supra, we bought new turbos. It was a good decision as turbos tend to be the weak spot. Since mine only had around 10k on them, I really didn't need to upgrade. However, I found a set of new JWT Sport 500's at a good price and decided to change them. As I went through the project, I found many more things I wanted to change.
What I ended up with:
300 degree fuel rail w/ 740cc Nismo injectors
JWT Sport 500 turbos
New lifters
New Alt and Battery harness
New Z1 Silicone Boost hoses (all of them from the turbos to the intake)
SS T-Clamps for all boost hoses.
New Z1 Silicone PCV, AIr, vacuum hoses (30 ft of various sizes from hosetechniques.com)
New Z1 Silicone Water/heater hoses
New knock sensor and harness
New Howe Radiator
New OEM oil hoses (all of them for the turbos, oil cooler)
New OEM PS hoses
New Master and slave clutch cylinders
JWT Sport clutch and lightened flywheel.
Remey idler studs
Remey Chromoly clutch pivot bolt
SS clutch flex line
Greddy ProfecB Spec 2 Boost controller
HKS Turbo Timer Type 1
New OEM Motor Mounts
99 Jspec front fascia
99 Jspec tails
KurumaZ spoiler and new 3BL
new decals for motor and spoiler
SS bolt kit for motor
New OEM FPR and Damper
Gates Injector hi pressure fuel hose
OEM Fuel filter
There is more, like paint and a gun, but this list is pretty complete. Needless to say, the budget went out the window.
Some pics of the motor when it arrived at my house...
The garage once all of the stuff started showing up. I had no room to move at one point. Boxes everywhere. I could tell it was the weekend because UPS/Fedex didn't show up!
New turbos...
bent waste rod...easily fixed. Got bent in transit.
New Lifters - I replaced all of them since several were very soft, mostly on the exhaust side.
Covers painted and installed...
Front of the motor cleaned and painted...
I had to cut the crank sprocket off the crankshaft. It was rusted solid. I broke my puller trying to get it off.
Top of the motor cleaned, painted, sealed and re-assembled...
Rear of the motor with new battery cable, silicone hoses...
Front of the motor re-assembled. I didn't like the rust in the coolant pipe. There is nothing I can do but regular flushes. I flushed the entire block while it was down and drained it. But, it takes time to get this stuff out...
Right side turbo installed...
Tight fit for the wastegate boost line. I had to grind the motor mount a little to make clearance...
Prepping the Z to pull the NA motor. I sold this to a buddy of mine. After 156k miles, the compression was 187/cylinder. It didn't vary one pound on any cylinder.
Pulling the motor...
The nasty engine bay. It amazes me how dirty these get even when I cleaned everything I could reach on a regular basis...
After cleaning up the engine bay and prep for painting the bay and underside of the hood...
Ready to paint...
Painted! You can see orange from the sunlight, that is the AG2 Aztec Red color...
Left side of bay with everything re-installed. I painted all of the accessories the same color as the valve covers (brake booster, power steering reservoir, cruise control, balance tube, etc...)
Right side. You will notice the second bleed point for the clutch is gone. I eliminated this as part of the conversion. I found a shop that makes custom tubing and took my old line and the junction block to them. They bent a new line, used the "nuts" from the old line (6mm x 1.0 thread) and made a new line that duplicated the old one without the junction block for $20. I found a 10mm to 10mm junction at Advance Auto parts and completed the deletion.
Line deleted...
A picture of the front end after all was put back into the engine bay. I positioned the Z at the end of the driveway while I straightened up the garage to install the motor.
Then tragedy struck...
My wife had been up all night working on coupons for food. She does this and saves a ton of money (67% of the normal bill), but was tired when she went to the corner store. She didn't see the Z and accidentally backed into it. I wasn't mad about it all. It isn't the end of the world and I can repair it.
The motor installed...
JWT sport clutch installed with the transmission...
And finally, some pics of her after I finished the conversion.
I have decided to name the Z "Sybil" after the multi-personality woman in the movie of the same name. The car drives just like an NA until you decide to hit boost. Then, Sybil changes into a very mean girl. I have been quite impressed with the power it is making. On stock boost (11.4 lbs), it walked right by a BMW M3 -2004. The guy was shocked. Also, without launching the car and shortshifting 1st gear at 3500 rpm, waiting for 2nd boost to build, it pulled 0-60 in 4.53 seconds. The funny thing is that it doesn't feel fast. It is very smooth.
That's the story. There is much more over the 8 yrs I have owned it, but this will give you an idea of the transformation both it and I have gone through since the time I first saw it sitting in a parking lot a long time ago.
