Mystery Oil Pan
General discussion area for the L30-chassis Altima
JSpeig
Car: 1998 Nissan Altima
Hello All,
Im working on my little sisters 98 Nissan Altima, and have had the hardest time with an oil leak at the oil pan gasket. We wanted to replace the pan since the previous owner banged it up from what looks like an off-road adventure...but we cannot identify the engine. The pan does not look like anything for that year or model car. At least not here in the US. Can anyone help?
What does the oil pan for the u13 Bluebird look like? From what i see under the car, its a very small (lower pan)..but it isnt square...almost square, with one side slightly shorter than the other...trapazoid?
picture is on my avatar profile pic and here
http://s90.photobucket.com/user/jordanspeig/library/
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
JSpeig
Thank you!
JSpeig
Anyone?? It doesnt appear that this was the original engine for this car.
lobo_s10
Car: 1998 Altima GXE 5spd, cold air intake, strut tower brace, fireball 2 muffler, vortex generators on roof
Take it to nissan and have them look for the pan off of the engine numbers that'll tell you if its the rite year engine anyway.
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Assuming you are in the US, it looks like someone replaced the engine with a JDM KA24DE (japanese version) like you said from a Bluebird. The dead giveaway is the bulged part of the valve cover with the fins.
US KA24DE valve cover:
JDM KA24DE valve cover:
Your engine should have an oil pan like this:
In either case, they use silicone RTV to seal the pan to the block (or upper oil pan in your case) so you don't need to find the proper gasket. I would just take off the oil pan, bang out the dents as best you can, clean the inside very well and the mating surface, and reinstall with some ultra grey or copper RTV. Bolts should be torqued to about 6-7 ft-lbs. Are you sure that's where the leak is coming from?
Return to “2nd Generation Altima Sedan (1998-2001)”
