My Wood/fiberglass wing splitters...ugh..idk
TheRealNap0le0n
Car: 1998 q45
bersh240 wrote:wood comes from trees. trees come from a forest. i peed in the forest. wood on your car is like having pee on your car.
quoted for epic lolz and sig purposes
TheRealNap0le0n
Car: 1998 q45
Darkness and Light wrote:Wood is used on ship hulls, ultralight aircraft and prop planes, actual racecars, the floorboards on the Corvette Z06, and a wood pulp ice aircraft carrier was manufactured in Canda during WWII. If you feel wood doesn't belong on a car well you're entitled to your opinion.
im pretty sure the corvette floor boards are not wood at all.... especially the z06.
and if you are refering to the c6 z06 most of the car including the floorboards is CF
Darkness and Light
Car: 1993 240SX Fastback, 1995 240SX Coupe SE
Yes, the Z06 uses carbon fiber with a balsa wood core. The core adds rigidity and separates the layers of carbon fiber. Like any cloth carbon fiber is strong under tension loads but drapes and bends. When cloth is separated by a core for one layer to bend the other layer is put under tension, think about flexing a phone book when the pages are held together or a thick piece of rope.
Wood is basically a composite like fiberglass, its uses cellulose fibers instead of glass fibers and hemicellulose and lignin as the matrix instead of polyester/epoxy resin.
