klattr1 »
https://forums.nicoclub.com/klattr1-u1743.html
Fri Sep 19, 2003 4:14 pm
have a 95 240sx fully built(JE oversized pistons 8.5:1 and Crower rods, Cometic headgasket and Jim Wolf cams. I run a setup very similar to Chris Mays.(72lb injectors, Cobra Mafs, Jim Wolf ecu)Well i hooked up the boost controller today and turned it up to 10 and then to 14 psi. No problems, No detonation, Fast as hell!But around 6:00 I boosted in 3rd gear all the way to 14(not past 14 at all) and then I heard sounds of detonation(marbles in a jar sound) and then I let off the throttle. Well I pulled off into a grocery store parking lot a half a mile down the street where i boosted and I noticed a severe loss of power(like running on 2 cylinder).I pulled the spark plugs out and the first and fourth cylinder spark plugs had no gap whatsoever. The arch was slammed against the electrode or point whatever you call it. NO GAP and charcoal burnt on 1st and 4th.I was like Oh SH(T. So my Dad brought his compression gauge and sure enough, 1st and 4th cylinders had 0 psi and the 2nd and 3rd had 110 psi(low compression motor).I looked at the tops of the pistons and no visible damage was done. What are yall's experiences with this?I will be pulling the head tomorrow to check out everything?Possible valves or piston rings?Obviously there was not enough fuel to support that boost level. So If i get it fixed right, I will have to check for stock fuel pressure regulator function and 300zx TT fuel pump function. I will prolly buy a new fuel pump.Help me out as much as possible with advice or personal experiences.14 psi felt good but only for 30 min.Thanks,RyanHere's my webpage with a list of parts and modificationsWebsite KA-T
