My Subaru wont start. Nico, come to my rescue.
nissangirl74
Just out of curiosity, did you get a clear title with the car? Any chance that it could have been stolen? You did say the PO was kind of a shady character. Some cars have a feature where the car can be remotely disabled if it has been stolen. Not sure if they had that technology in '02 and I just remember hearing that from someone. Not sure if it's true or not.
PoorManQ45
FlatBlackIan wrote:Subaru did not start installing key based immobilizers until 2005, and it was only on the STI model until 2006.
I only have a single key for the car, and it is not an original. I have pulled the cowl off the column, as far as I can tell, there is no sensor ring on the ignition, just the trigger for the key beep.
Hmm, if you can, take apart the ignition and just make sure. It is possible that it was upgraded to a newer module at some point to add the key immobilizer.
That's a shot in the dark, but anything is possible, and that's easier then going inch by inch over the harness.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Kenne21 wrote:still waiting to hear back from him...he takes forever ill let you know when he gets back with me on that
in the mean time...what about your cam sensor being bad? you said you checked grounds...did you just check there connections or did you trace the wires and make sure they were un harmed? might have nicked one and it broke just enough to not work now
Cam sensor will not fully disable the engine, just make it batch fire. I have continuity tested the wires, and they all check good, for cam and crank.
Kenne21 wrote:Ok in response my buddy said:
lockout box is just the term i use, its just his security system. might be a dealership issue. ill ask around but i think theres something funky going on with his security.
engine managment is a f'd up thing to deal with
Thats what I thought. Hopefully someone has experience this before. Im contemplating buying a new security module.
nissangirl74 wrote:Just out of curiosity, did you get a clear title with the car? Any chance that it could have been stolen? You did say the PO was kind of a shady character. Some cars have a feature where the car can be remotely disabled if it has been stolen. Not sure if they had that technology in '02 and I just remember hearing that from someone. Not sure if it's true or not.
Never stolen, never wrecked. By shady, I meant he was like 19, and didnt know squat about cars, and wasn't about to answer any of my tough questions.
The key based immobilizers use a sensor ring mounted to the base of the ignition cylinder. Its right on the end, and if its there, you see it. They need to be close to the butt of the key, where the RFID chip is located.
IanS
WWell with the busy holiday season over, I finally got some time to reexamine the Subaru. It has just been sitting untouched for 2 months or so. After poking at things and testing everything, ITS ALIVE!!!!
Here is what I figured out. Part of the wiring harness was pinched. It was stewing up cam and crank signals. Replace the whole harness, car still wouldn't run.
Now had injector pulse at all cylinders. Discovered one cylinder had no spark. Turns out one of the coil packs had a little corrosion. Cleaned up, and it started firing, but only on one cylinder.
Undettered I pulled the plugs. Only one plug showed any sign of fuel. All the injectors ohmed good, but I decided to throw a hail merry. Replaced all the fuel injectos, and she fired right up.
Multiple problems FTL.
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
yeah for sure they suck. but now you got a sweet ride again.
IanS
Zydeco wrote:yeah for sure they suck. but now you got a sweet ride again.
Again? Whats wrong with my truck? :poke:
You're mean. ;)
PapaSmurf2k3
Site Admin
PICS! VICTORY DONUTS!!!
IanS
PapaSmurf2k3 wrote:PICS! VICTORY DONUTS!!!
Half of the front body work is missing, and the power steering resivoir is empty because I don't have any atf lying around. Maybe next week before it goes to the body shop.
PapaSmurf2k3
Site Admin
Last time I checked, you could do victory donuts and take pictures without a front end and lacking power steering :)
IanS
PapaSmurf2k3 wrote:Last time I checked, you could do victory donuts and take pictures without a front end and lacking power steering :)
Dont want snow in bad places, and I would prefer not to destroy the power steering pump.
Solar_Runner
Nice - glad to hear you got it running. Funny that stepping away from something like this will bring some clarity of thought later.... you come back to it and BINGO!
PoorManQ45
How much were the injectors?
Usually they're pretty pricey. That would have sucked if that didn't fix it!
Good job!
IanS
PoorManQ45 wrote:How much were the injectors?
Good job!
Free.
I pulled the injectors off the other motor. Win win.
PoorManQ45
Good deal!!!
