SullivanRacing06 wrote:gas in the tank? stupid question but sometimes we over look things like that, after you try n start the car and it "floods out" and ya pull the plugs are the wet at all? fuel on them? or are they dry, if there dry then no fuel, if they are wet then no spark, motor need 3 things, spark fuel and proper timing, if your gettign these three things theres no reason it will not start, have you done a compression test on it yet either? might be a bad motor, if you get low compression readings drop some marvel mystery oil in the low cyls and turn the motor over, it mite have some stuck rings
SullivanRacing06 wrote:coolant in the oil , means bad headgasket or cracked head
ok i normally don't see you make dumb posts so i'm going to assume you SKIMMED this thread instead of reading it... he said that the car starts but misfires and smokes... there is NO coolant in the oil.. read below..
Romeo_rus wrote:Tried to start it again... starts good, misfires badly... spits out a lot of fuel trough the downpipe.. a lot of white-blue smoke... I waited untill the car got warm, then checked radiator - there is no oil, coolant is pure green... checked the deepstick - there is NO coolant in the oil... this evening going to check/replace o-rings...
this problem was said by carl to most likely be caused by bad o-rings on the injectors... if you read back, you'll also see where we stated that we had pulled the injectors out... there are even some nicy blurry pictures... lol either way, please read posts before replying thx man do appreciate the attempt to help
oh yeah.. look up even more and you'll see where i had stated the car started and ran smoothly... the new problem is the injector problem so obviously there is fuel..
