Hey man, I finally got my car started, I couldn't determine what the real cause of my problem was, but I checked all my cables, soldered and shrink wrapped everything following the
http://www.frsport.com wiring guide, take your time. So after doing all that I tested my CAS. What I did was pulled the valve cover off, set the car to TDC, took the CAS out, took the fuel rail out (with injectors pluged into it) and got a spark plug into a coil and ground it. With the ignition key in the ON position turn your CAS by hand. While turning your CAS your injectors should and must spray gas, make sure you point the injectors to a safe direction. So that passed my test. This ment that my CAS, Ignitor, ECU and coils are good. So I was like why the hell didn't the car start, and I followed the FSM to set timming and all it took me was 15minutes to do this, first turn of the key and . This was at like 11pm with no exhaust, my neighbor yelled and just said, finally. If you need any help send me a PM and I'll tell you more about all the crap I went through. Good luck.
Also make sure you don't have your spark plug near the fuel line with the injectors out, you might get something burned, do it one at time for safety.EDIT: Here is the link to set your timing
http://www.frsport.com/How_To_....html
