I finally got my Megasquirt ECU to hold an idle. This was one of the best feelings... EVER(and no im not a virgin ). This things been kind of a head-ache(a faulty ground was making my timing go all over the place when i had my injector's plugged in, after i fixed that it held timing great), but i have a feeling im going to really like the stand alone system.
Megasquirt itself is a cakewalk to install with the relay board. Granted you dont need the relay board at all, you can use your old relay's and fuse box with MS and you can save about 70 bucks. I however wanted a fresh start so i went with the relay board and butchered my stock harness. I am running the stock ecu as a piggyback to control my IAC, as well as my FCID valve because my AC blows to cold to get rid of. While MS is supposed to be able to handle these, no research has been done on how to do it so i went the easy route. Also, i switched to an external coil, which means im running a s13 distributor on my s14. I kind of went with the flow with everything, i was trying to do everything as simply as possible.
This is the link to the page that spurred my project ---->
zerothread?id=221623 I got everything from DIYAutotune. Matt Cramer over there is one heck of a nice guy, he pretty much runs their customer support. I have never in my life dealt with a company that has anywhere near the kind of support that guy gave me through this project. Im sorry if it seems like im advertising for their company but i still cant get over how helpful those guys were. If any of you chose to go the MS route, DIY autotune is the place to do it.
My setup is nothing special, baring the MS. -S14 120,000 Miles in great shape, compression and all(ebay) - 5000.00 -Megasquirt 2 completed ECU - 410.00 -MS completed Relay Board - 88.00 -MS Relay cable - 70.00 -GM Open element IAT sensor + Bung - 30.00 -S13 dizzy(Nico) - 35.00 Shipped -s13 Dizzy pigtail(Nico) - 20.00 Shipped -MSD Blaster coil(ebay) - 30.00 Shipped -Ebay special Wires + Iridium plugs - 40.00 Shipped(cant pass that up!) -XS Power 50 trim t3/t4oe Turbo - 300.00(ill upgrade when i get the cash..) -Boost Designs Manifold and DP(NICO) - 450.00 Shipped(had to modify the DP because apparently there are a few different types of 5 bolt T3 flanges) -DIY Oil feed line, Works Great --->
zerothread?id=96306 - 60 or so bucks shipped -DIY Custom Hydraulic Oil return line(local hydraulic shop) - 30.00 -Oil feed, oil return flange ---> http://www.roadraceengineering...s.htm- 35.00 -Tial 38mm Wastegate (NIB, Nico) - 130.00 -SARD R2D2 Bov(Ebay) - 135.00 -Cometic Uncoated HG (Nico) - 90.00 -ARP Head Studs(AMS) - 130ish? - Used Sard 550 CC Injectors(ebay) - 220.00 Thats all i can think of for now, im sure i left out some things and as i remember them ill toss them up on my list.
This is just the first post, more to come as i get my IC cooler piping all tiged up and my turbo actually connected. Ill be putting up a bunch of pics here soon too, just wanted to get the word out that MS will actually run your car ^^. Btw, you guys have helped me so much, Nico owns!
Here she is, in all her stock glory So much for that
