My S15 powered S14 240SX 1/4 mile times
nisstek
Car: S14 w/S15 SR SOLD, S13 Coupe, 04 Titan, 1991 300ZX, 03 Max
I just ran a 14.40 at 98 MPH at Bristol Dragway. Bone stock S15 swap, 10 psi boost, APEXi N1 exhaust, BLITZ downpipe, gutted cat, Greddy Suction pipe. I think the driver slowed it down about 3 or 4 tenths. :D What are you S14/S15 SR guys running in better air?
BuudWeizErr
You should be hitting 13's on 10psi.
Or do you have a SMIC?
what was your 60' ?
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
hm...u sound like ur not the best driver...:D
240SXer
Car: 1995 240sx SE (2jz powered)
You should be pushing around 290hp with that setup. 14.4 isnt that good. How was your traction? Post the entire time slip
nisstek
All stock. side mount and all. 60'= 2.11. thats the driver factor hindered by KUMHO's. My tach is FUBAR so I'm short shifting at least 1 gear per pass. All I need are sticky tires, a tach (very important when drag racing), and practice to run 13's. Its been 10 years since I last went down the 1320. No its not like riding a bicyle. I'm pretty proud of my 14.40, though.
nisstek
Here's my time slip as requested.
R/T 0.04160' 2.184330 6.0791/8 9.297MPH 75.711000 12.0771/4 14.438MPH 97.18
gibbo80
nice rt, im glad someone is posting with that engine, rarety it seems
Rockenreno
Car: 1997 BMW M3
yeah, I would think you'd be able to run high 12s once you get it down. I know people who run low 13s with pretty much "stock" s13 redtop sr20s... with an s15 engine... *gah* :drooling:
I'm sure you'll see your times get better significantly as you as a driver improve. Good luck!:D
TurboKA37
do u have a sound system or anything else adding weight to ur car?
Unnatural
Let's not forget that Nisstek is running in Bristol, TN. Bristol Dragway is 1,475ft. above sea level. I forget what the official correction factor is but he is posting uncorrected numbers. That 14.40 would have been a bit quicker at sea level and the 98mph trap speed would be faster. A 2.1 sec. 60' is not all that bad on street tires (excluding DOT slicks/drag radials). Get that tach fixed and try it again. Then rip that SMIC out of there and throw it on eBay. Get a FMIC kit for that S15!
How'd it feel to get back on the 1320 again? That's a very nice setup you have there. Good to see an S15 swap! :thumbup BTW did you get the A/C to work in your S14?
nisstek
Rockenreno wrote:yeah, I would think you'd be able to run high 12s once you get it down. I know people who run low 13s with pretty much "stock" s13 redtop sr20s... with an s15 engine... *gah* :drooling:
"Pretty" much stock Red Tops dont run 13's. I dont care if Bob Glidden or Warren Johnson is driving. With the setup I have, my car will not run any better than 13.8 (at Bristol). That would be everything perfect. I'm man enough to accept that.
I H8 UR DSM
with the mods you have and tires, and boost, i'd say low 14 would be about right.
zombieman
did you have lsd on your car?
a stock s13 sr20 runs 14.5 or was 14.7, all i remember was that it ran under 15.
nisstek
zombieman wrote:did you have lsd on your car?
Mid 14's sounds closer, I'm thinking HI 14's. But there's not any around here that I know of. Yes its a helical unit out of the S15. All S15's are LSD, according to my Aussie Service manual. before I get flamed for having an Aussie motor. No its not. Aussie motors wont do 10 psi stock.
Jookmasta
well u have a sweet reaction time and like it was said b/f, the 60 time is also good. FMIC is the way to be. get that thing and you will be in the 13s even on ur lousiest day. blame it on the air.
Snoboarder793
Car: Snowboarding, Cars
theres a S15 front clip complete with ecu and 6 speed transmission and everything for 2900 right now and theres only 13 hours left in the auction i dont know but that sounds like an awesome deal to me
nisstek
A little off subject, but you gotta have the rear LSD and driveshaft. The six speed combined with slightly longer pinion, because of the speed sensor, in the rear end makes the driveshaft about 2" shorter.
nisstek
I'll bet that auction mysteriously ends just before the time is up.
yashin
Car: football, rugby
doesn't an actual s15 silvia run a stock 1/4 mile of 13.9?? with the weight being the same you should run this as well
nisstek
yashin wrote:doesn't an actual s15 silvia run a stock 1/4 mile of 13.9?? with the weight being the same you should run this as well
Everything I read says 14.20 @ 101 MpH
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
I get sub 13 im my car in the 1/4.
did i mention that was minutes?
sr240se
You shouldn't be running 14's in teh quarter, fi you dont' know how to launch that damn thing. I was happy with my 13.00 with no differential and at 15 psi with a nice front mount. Learn how to launch!!
nisstek
sr240se wrote:You shouldn't be running 14's in teh quarter, fi you dont' know how to launch that damn thing. I was happy with my 13.00 with no differential and at 15 psi with a nice front mount. Learn how to launch!!
I was wondering when Shirley Muldowney was going to jump in!13 flat??....whatever dude. Read the whole post prior to making yourself looking like a jerk.
y3llows14
Hmmm...no differentials huh? How you gonna put those 13 second 1/4 passes power to the wheel?
Rockenreno
Car: 1997 BMW M3
nis... I still think you could run low 13s or high 12s with just some minor engine work/tuning (FMIC, boost controller tuning, etc) and some practice. Lets keep in mind that 14s is still damn fast, but I think you'll drastically improve once you get used to the car more :D
Once again, good luck!
nisstek
The voice of wisdom. I think you are 100% correct.
GodzillaFan
i tend to agree with some of the posters here... your running a slower trap speed then a stock s15, with mods (exhaust)but that could all the attributed to your messed up tach...and slightly heavier s14what were the temps at the track?
btw, does anyone else realize that 10psi is 10psi be it at 0ft above sea level or 9000 feet? :D
Unnatural
GodzillaFan wrote:i tend to agree with some of the posters here... your running a slower trap speed then a stock s15, with mods (exhaust)but that could all the attributed to your messed up tach...and slightly heavier s14what were the temps at the track?
Boost pressure is relative. While you may see 10psi on your boost gauge (aka psig) at "9000 feet," I guarantee that the volume of air you're moving is much less than it would be at sea level. The further away you are from sea level the less dense the air becomes. The same effect can be felt on hot and cold days. Boost pressure has little to do with power. What's important is the volume of air you can move at a given boost pressure. However, that boost pressure will vary with mods and environmental conditions. Speaking in terms of ultimate power output 10psig at sea level is very different from 10psig at altitude.
Snoboarder793
I concur
jrc90240sx
yeah tell me about it, damn 4500 ft above sea leavel sucks.
you could figure out the amount of boost someone as sea leavel would have to run to make the same power your making. witch i guess would be around 7psi boost at sea leavle would equal your 10 psi boost.
but yeah that some nice times. i have yet to run my car because its a pic of crap.
