My S15 powered S14 240SX 1/4 mile times
nisstek
Car: S14 w/S15 SR SOLD, S13 Coupe, 04 Titan, 1991 300ZX, 03 Max
mmdb...the tach works just like it did with the KA in it. Its a NISSAN thing. I've seen lots of 'em do that. I luv the six-speed...close ratio, slickshifting, just a tad whiny because of straighter cut gears. I have'nt gotten my speedo or AC working yet because it aint making the car no faster. I'll work on that stuff later. I have the S15 cluster and ABS controller just no time right now. I would put up pics but somebody would have to do it for me. No webspace that I know how to use.
Unnatural
nisstek wrote:...It's all good, though. Hell, what do I care. My 240 has an S15 SR20DET in it.
LOL! :ylsuper That's so true. I've probably got some spare webspace around that I can host those pictures for a while. Let me know.
egan
i would love to see pics too, please :)
mmdb
From what i read the speedo has to be hooked up to have the VTC working. It meant hooking up the signal from the diff to the abs ecu, to the speedo and then to ecu.
I'll look for the post that had something who wired up everything up correctly.
Jookmasta
yea get the pics up plllllllleeeeeeaaaaaaaasssssssseeeeee
DRT_240sx
Car: 95 zenki 240sx se
no matter what he got 1/4 mile the man deserves much respect. I bow down to you at this moment, but only untill i get my s15 clip aswell. Job Well done.
nisstek
mmdb wrote:From what i read the speedo has to be hooked up to have the VTC working. It meant hooking up the signal from the diff to the abs ecu, to the speedo and then to ecu.
Thank god for Factory service manuals......The inputs required for VTC opreration are:
Intake air signal (From MAF Sensor)Engine Speed Signal (From Cam Pos Sensor)Engine coolant temp signal ( From ECT Sensor)Throttle Valve idle Position (From TPS)Gear position (From park/neutral pos switch)
Now you dont have to look it up because I already did. :pface
GTS4-R
Car: my feet
Signals definately go from sensor to ECU then to the cluster (ie. tach, speedo, etc.).....the ecu reads everything first then its sent elsewhere........
