joenismos15 »
https://forums.nicoclub.com/joenismos15-u68758.html
Wed Jun 04, 2008 5:23 am
Clutch is now in, Battery is Hooked up, Alarm system is wired up, Working on the Boost Controller, Still have to get it tuned and break in the Engine but progress is being made.
Drivetrain /SuspensionGot the Transmission deburred and replaced all the synchro gears, got the Nismo 1.5 way diff installed the DSS driveshaft installed, DSS axles installed, Fidanza flywheel is installed, Fidanza 4.3 Clutch is now installed. Energy suspension Bushings installed, Cusco Rear Strut bar installed. Nismo Subframe bushings are in.
Motor/FunstuffRemoved original Engine, installed the AMS Crate Engine got all the sensors hooked up, New Alt installed,new Dizzy installed, new waterpump installed, Got the OBX Pulleys installed:Alt, Crank, water pump. Reinstalled the Greddy Turbo Kit, Relocated the battery to the trunk have it bolted Down.Greddy Intercooler is installed, Greddy Radiator installed, Greddy BOV is installed (Vented Atmosphere Running Map Sensor For now) And a lot more done that i cant think of right now.
