My S13 VH45DET build thread
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
well i started by finding a motor and 300zx trans on craigslist for 500$ and picked that up, was just planing on changing guides and calling it a day but as soon as i pulled the valve covers off, i knew that wasn't gonna happen. the motor was super nasty with sludge that was damn near rock hard like a crust. so i ripped it all apart and sent it down the the machine shop, for a hone, deck, cleaning and valve job.
i have no before pictures but the machine shop guy said it was the nastyiest motor head ever seen lol
currently i'm waiting on my bearings to show up so i can begin assembly
still have alot of cleanup to do but until i get bearings i'm kinda at a stopping point except for all the cleaning!
tr4c3
Car: 94 240sx Vert
Post some more pics. What are your specs of the build? My bro and I are doing vh swaps as well, I've been tossing up either going procharger or single turbo with my vert, starting to lean towards single turbo again.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
well its just a stock rebuild. i just had to clean alot of parts up.
Uploaded with ImageShack.us
i'll have some more engine pics up as i clean more parts and get stuff in.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
got the powersteering pump figured out and cleaned up. i'm using an sr20det PS pump with the vh45de's brackets and they all bolt right up expect for one hole witch i dont think will matter. painted the brackets and pulley with black wrinkle paint.
i also painted my oil pan with spray on truck bed liner
more to come tomorrow when i pick up my cylinder heads :dblthumb:
b20vtechb
Car: 90 S13 hatch
VH45det in progress
well still waiting on my heads to get done, but i did get my mount kit and driveshaft in, and finshed cleaning up my crankshaft.
Polished and deburred crankshaft
Mount kit from Xcessive
VG-S13 driveshaft from Xcessive
Oil pump disassembled ,cleaned and polished the rotors
Timing chain kit
Polished piston only 7 more to go lol!
Painted some more brackets and pulleys.
Rod bearings.
Front and rear main seals, and nismo pilot bearing.
Clutch masters Stage 5 4puck unsprung
mtmetzger
Car: 1993 240SX coupe
Looks like it's going to be a quality build! Where did you get your timing kit from? I'm in the market now. :)
b20vtechb
Car: 90 S13 hatch
VH45det in progress
mtmetzger wrote:Looks like it's going to be a quality build! Where did you get your timing kit from? I'm in the market now. :)
http://cgi.ebay.com/1990-1996-Infinity- ... 45f5815a93
250$ pretty good deal i think!
hannibal
Car: Red Line to Glenmont
I'm assuming the SR20 PS pump with VH bracket clears the frame rail. I'd like to see a pic once the engine's mounted. Sound like a good solution.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
block after the final clean
Crank installed after a final clean of the block and crank, getting all those plugs out of the oil galleys was a pain in the a**. had to drill out 4/5.
i should have the heads this week, and hopefully have the long block assembled by the end of the weekend
b20vtechb
Car: 90 S13 hatch
VH45det in progress
got 6/8 of the pistons/rods installed, and painted the front cover.
got 1 more piston left to polish. and still waiting on my heads
b20vtechb
Car: 90 S13 hatch
VH45det in progress
got the rest of the pistons installed and the windage tray and oil pickup put on
b20vtechb
Car: 90 S13 hatch
VH45det in progress
picked up my heads today. and they look very good!
The machine shop had some difficulty removing 3 of the HLA's and had to do this to get them out of the head.
so i had some sr20det HLA's laying around and noticed they were very similar except for the grove and the top portions
vh on left sr20 on the right
vh45de on the left sr20det on the right
so i pulled the extra sr20det hla's apart to see if the 3 vh45 hla tops would fit into the sr20 hla lower
sr20 on left vh45 on right, notice the slight height difference and the profile of the ball on the top is a little bit different too.
tmorgan4
Car: 2000 Nissan Pathfinder
You're doing an awesome job on this engine. Everything is clean! Too bad it won't stay that way for long.
While you have the front timing cover and oil pump off, is there any way you could remind me how the oil passages work? Even some pictures would be great. I'm trying to remove the factory oil pump but feed the factory oil galleys. From what I can remember and looking at FSM diagrams, it looks like the oil gets sucked up by the oil pump, out into the oil tree (which port is in/out (left or right?)), BACK through the pump, and into the main galleys for the block. How does oil get from the oil filter to the galleys? Does the OEM pump have to be there? It's been so long since I put mine together I'd really appreciate some help if you have a few minutes.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
tmorgan4 wrote:You're doing an awesome job on this engine. Everything is clean! Too bad it won't stay that way for long.
thanks man! hopefully this will help ya
b20vtechb
Car: 90 S13 hatch
VH45det in progress
got the heads put on today, working on finishing all the HLA's and timing stuff next
and a little preview of the fuel rails i'm working on for the stock manifold
and all bagged up for the night
b20vtechb
Car: 90 S13 hatch
VH45det in progress
little update for today, got the cams in and timing set, painted the upper front covers. and got all those bolted on.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
got some more stuff done..
installed the water pump and got my valve covers painted
waiting on my new knock sensors to show up before i can bolt the coolant stuff on.
got my turbo in, gotta clean it up a little but it seems to be in good shape.
billet Ti wheel
HeadAblaze
Car: Now: 1971 Datsun 510 w/ ka24e
Sold: Red 1990 240sx hatch
Looks smooth! The motor is very pretty. Kinda whatyou'd want to see when you pop the hood.
klh6686
Car: '92 FB stock daily
'90 FB w/ RB20
'92 FB w/ VH45
Gotta love building an engine in your living room haha. (not hating, just saying... I've built one in a kitchen before lol)
b20vtechb
Car: 90 S13 hatch
VH45det in progress
klh6686 wrote:Gotta love building an engine in your living room haha. (not hating, just saying... I've built one in a kitchen before lol)
lol yeah didn't have anywhere else to do it.. plus helps keep it all clean.!
got the motor dropped in. haven't centered it or leveled it yet but mainly just looking at clearances.
but it does look damn good in there!
b20vtechb
Car: 90 S13 hatch
VH45det in progress
ok got one of my fuel rails done.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
well project has kinda been on hold due to winter and having nowhere to work on it but i've been saving up some money and planing out some stuff. got my oil cooler in the other day its got 12an fittings and is tube and fine design plus its nice and big. so i shouldnt have any oil temp issues. heres a couple pics for now and hopefully i can get my injectors ordered in a week or 2 and do a test fire on the motor.
klh6686
'90 FB w/ RB20
'92 FB w/ VH45
awesome work on the fuel rails man!
driftrkp
Car: 93 240 coupe vh45det
93 240 coupe rb25det
witch holset is that?
b20vtechb
Car: 90 S13 hatch
VH45det in progress
driftrkp wrote:witch holset is that?
Holset HX52 with the MFS billet wheel
driftrkp
thank you. i been trying to find witch holset would work best on my vh with no luck i was thinking hx40 but they look to be a liitle to small and i can get two hx35's so i thought about twins but think they mite be alittle two big?
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
little inspiration for ya glenn....This guy has a build on ka-t.org, he plans on taking it up to 8,500rpm so he has a useful power band. I believe he's only on 15psi on this run
Ka24de
*Holset HX55 Turbo with billet compressorwheel (19cm2)
http://www.youtube.com/watch?v=s1D6Jcmy3l4
b20vtechb
Car: 90 S13 hatch
VH45det in progress
got my fuel injectors in the other day , waiting on a ton more stuff to come in the mail, also ordered 2 of the new 340lph aeromotive stealth in tank pumps.
i think i should have enough fuel 1200 cc bosch ev14's
old 1000's on the left new injectors on the right
b20vtechb
Car: 90 S13 hatch
VH45det in progress
studs welded to the adapter plate and ground back down
thread inserts put in
plate bolted on
flywheel on with flex plate spacer and arp bolts
transmission bolted on
sitting in the car
and some carbon fiber accents for fun
some of my header making stuff should be in next week, and also most of my fuel system and oil system parts, so things should start moving decently quick now
b20vtechb
Car: 90 S13 hatch
VH45det in progress
5/8" fuel line for the feed
bunch of fittings and FPR
oil filter block
intake manifold modified for the top feed injectors
lancer evo calipers with 09 G37 rotors. i need to get caliper adapter brackets machined can anyone on here do that from an Inventor drawing?
pipes for the turbo manifolds
Return to “VH45DE / VK45DE / VK56DE Forum”
