My S13 VH45DET build thread
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
klh6686
Car: '92 FB stock daily
'90 FB w/ RB20
'92 FB w/ VH45
That last picture makes me excited!
Carl H
where did you get the pipe for the exhaust manifolds?
b20vtechb
Car: 90 S13 hatch
VH45det in progress
Carl H wrote:where did you get the pipe for the exhaust manifolds?
ace stainless www.acestainless.com awesome place best prices on the web i'm pretty sure
DRFTBLD
Car: 89 S13 VH45DETT
05 Ford F-150 Drift Support
91 S13 Tester
08 Ford Focus
Nice build! Like the work your putting into the engine!
Also did you use the stock pistons or aftermarket?
b20vtechb
Car: 90 S13 hatch
VH45det in progress
DRFTBLD wrote:Nice build! Like the work your putting into the engine!
internally the motor is all stock. just cleaned the s*** out of everything, fresh rod and main bearings , crank micropolish , sanded down and polished the piston tops. block decked heads milled and a valve job.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
finally moved into a new house with a garage!!!
got my collectors and flange in
bunch of s***
finally got the fuel pumps that have been back ordered forever
i should be able to start making some good progress now that i'm settled in and have a place to actually work on the thing regardless of the weather!
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
Where are you planning on putting the turbo?
Looking like it's going to be one hell of a ride.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
little bit of progress...
klh6686
'90 FB w/ RB20
'92 FB w/ VH45
Wow, that looks amazing! Sick work and props to you my man!
b20vtechb
Car: 90 S13 hatch
VH45det in progress
klh6686 wrote:Wow, that looks amazing! Sick work and props to you my man!
thanks alot man! i'm pretty excited about getting this damn thing done. then me and my friend can start on his r32 gtr
working on the fuel lines
i for some reason got a random idea to use heat shrink on the fuel line and i think it turned out great!
more manifold fun
DRFTBLD
91 S13 Tester
08 Ford Focus
What valve work did you get done?
Love the build so far. The manifolds look pretty cool.
DRFTBLD
91 S13 Tester
08 Ford Focus
Also forgot to add, What is the fuel set up your running?
b20vtechb
Car: 90 S13 hatch
VH45det in progress
thanks! the valves where ground and the seats redone and new stem seals
b20vtechb
Car: 90 S13 hatch
VH45det in progress
more fun... now i just have to take them over to a friends house and tig everything
also to answer your fuel question. 1200cc bosch ev14's twin aeromotive 340lph pumps single 5/8" feed "10an" split into 10an to 8an y block, then the rails then a1000 10an FPR and back to the tank with a single 1/2" "8an" return
darktalon2gnt
Car: 1992 240sx coupe 1994 q45
I was wondering how to fit at least a single turbo in the bay..you think a similar setup for duals would work? with one smaller turbo in each corner? I'm using a custom manifold so that would make plumbing easier i'd hope... also, what engine management you using?
sickness14
Car: 95' S14 SE. RB25 Neo. ARP, Tomei 260's, HX40 Pro, PFC, Synapse, Greddy
Excellent work. What is your educational / work background? Looks like you have previous experience building engines.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
sickness14 wrote:Excellent work. What is your educational / work background? Looks like you have previous experience building engines.
i've worked in a couple shops just going oil changes and s*** like 10 years ago lol. but i just have a really high mechanical aptitude. i've built and tuned alot of turbo honda's before i got this 240. but other then that i just like to learn from doing, nothing like good old hands on experiance!
darktalon2gnt wrote:I was wondering how to fit at least a single turbo in the bay..you think a similar setup for duals would work? with one smaller turbo in each corner? I'm using a custom manifold so that would make plumbing easier i'd hope... also, what engine management you using?
well this was the only way i could think to do it short of relocating the radiator like jeff taylor did. and i can't think of any reason why you couldn't run twins with one in each corner. i'm going to be using a 1010 aem ems just like jeff taylor used on his. cause really if you plan on throwing boost at this motor you would spend allmost as much on getting a bigger maf and the stuff you need to chip the stock ecu as you would just buying a used honda ems and adapting it.
asmcnally
Car: 1985 RX7 VH45 powered
Ohh, pretty. I'm currently in the process of re-doing a VH swap into an FB Rx7. What size piping are you using? Seems to be fairly large stuff. I'm constructing a log stle header currently using 1 3/4" runners into a 2.5" log. Looks similiar sizing to me.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
asmcnally wrote:Ohh, pretty. I'm currently in the process of re-doing a VH swap into an FB Rx7. What size piping are you using? Seems to be fairly large stuff. I'm constructing a log stle header currently using 1 3/4" runners into a 2.5" log. Looks similiar sizing to me.
basicly yeah , its 1.5" schedule 10 for the runners and then collects into 2" schedule 10
b20vtechb
Car: 90 S13 hatch
VH45det in progress
took the headers out and took them to get the flanges blasted.
got the driverside fuel rail totally done
depinned all the ecu plugs and getting ready to start the wiring fun!
b20vtechb
Car: 90 S13 hatch
VH45det in progress
and the progress from last night..
silv8
Car: s13 vh45det
Nice build. Can you tell me if you still have original oil filter Bracket locator that bolts into the pump what direction the oil flows. ie the top hole flows through the center of the oil filter or vise versa. I see you to have done a relocation for the filter and your help would be great. \
thanks
b20vtechb
Car: 90 S13 hatch
VH45det in progress
silv8 wrote:Nice build. Can you tell me if you still have original oil filter Bracket locator that bolts into the pump what direction the oil flows. ie the top hole flows through the center of the oil filter or vise versa. I see you to have done a relocation for the filter and your help would be great. \
thanks
i want to say that all oil filters flow the oil into the outside part then out of the center hole back into the motor, i'll have to check later to confirm that.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
heres some more progress for now
b20vtechb
Car: 90 S13 hatch
VH45det in progress
heres a little more progress
fuel lines all ran
notch for the alternator
oil crap
tmorgan4
Car: 2000 Nissan Pathfinder
More info on "oil crap" please. Did you remove the plugs from the side of the block or make an adapter to replace the factory oil filter tree?
b20vtechb
Car: 90 S13 hatch
VH45det in progress
tmorgan4 wrote:More info on "oil crap" please. Did you remove the plugs from the side of the block or make an adapter to replace the factory oil filter tree?
stock tree cut off right at the block basicly and 12an fittings welded on
DRFTBLD
91 S13 Tester
08 Ford Focus
How'd you get the hard lines so straight? They don't even look like they are hard lines!! Nice job.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
little more progress. got the manifolds all welded up and only have to fab up the wastegate portion .
i pretty much trashed the stock fuel hat trying to figure out a way to fit 3 -8an fittings on it, so i dumped it and picked up a q45 fuel hat and that worked a million times better.
oil system is done also.. just have to make the mounting bracket for the filter housing
so basicly where i'm at now is bracing the turbo side manifold , mocking up the wastegate , whole lot of wiring , and probly a bunch of other misc crap i'm forgetting about. but thats the bulk of it.
b20vtechb
Car: 90 S13 hatch
VH45det in progress
and a little more stuff
wheel spacers will be in early next week.
Return to “VH45DE / VK45DE / VK56DE Forum”
