AZ89two4Tsx wrote:What kind of exhaust is on there? I didn't see it in your mods list.
Apexi N-1
Engine parts list, here's the checklist I used to keep track of what I needed or wanted to get.X=purchased-=not yetENGINE---------------------------SR20DET Redtop w/5spd.transmission X-JSA Motors (ENGINE INSTALLED ON 11/2/8!!!)Motor Mounts-NISMO X-EbayNismo Engine Mounts X-West CovinaValve Cover-Redtop X-Phase2MotortrendValve Cover PCV Valve X-West CovinaValve Cover Bolts X-Bonehead PerformanceValve Cover Washers X-Powdercoated by Bonehead PerformanceCrank Angle Sensor Cover X-EbayGreddy Oil Pan X-Askme4parts.comOil Strainer S14 XOEM Oil Strainer Gasket XMagnetic Oil Drain Plug X-EbayOil Drain Plug Crush Washer X-West CovinaMain Oil Seal-Rear X-Performance NissanMain Oil Seal-Front X-Performance NissanOil Filter Nissan-OEM X-West CovinaOil Filter Relocation Kit X-Greddy(use of of GReddy oil filter or 1985-87 Toyota Corolla GTS Oil filter required)SR P/S Pump (USED) X-nicoclub.com ForumPowersteering Belt-Gates X-West Covina
TURBO---------------------------- Greddy Profec B Spec II X-Boost ControllerGreddy Turbo Timer X-EbayCircuit Sports TT Harness X-Askme4partsIntercooler OEM Sidemount X-NICOIntercooler Piping OEM X-NICOIntercooler Duct OEM X-EbayIntercooler Hotpipe/HKS BOV X-Phase2MotorsportsT25 Turbo Manifold X-IntenseMotorsportsTurbo Elbow Megan Racing X-EbayOEM Exhaust Manifold Washers X-West CovinaOEM Exhaust Manifold Nuts X-West CovinaOEM Turbo Locking Tabs X-West CovinaO2 Sensor-Redtop-Skinny Type X-Performance NissanO2 Sensor Adapter X-EnjukuracingTurbo Inlet Hose X-AutoZoneTurbo Elbow Studsx3 X-Phase2MotortrendTurbo Lines-Steel X-Circuit SportsDownPipe-3" X-Ebay Wrapped in heat wrap and treated with silicon spray for protection!A.I.V. Plug-HeavyThrottle X-HeavyThrottle Not needed!Thermal Wrap X-Askme4parts
DRIVETRAIN-----------------------OEM Transmission Bolts X-EbayNismo Transmission Mount X-West CovinaNismo Pivot Ball X-Askmeforparts ebay sellerClutch-Exedy Stage 2 X-EbayClutch Slave to Cylinder Line X-Askme4partsClutchline-Stainless Steel X-ProjectSilviaFlywheel-ACT Streetlite X-EbaySteel Driveshaft -Underdrive Pulleys-Greddy X-Phase2MotortrendRocker Arm Stopppers X-Greddy Steel Braided P/S Line -Askme4parts
ELECTRICAL-----------------------Spark Plugs-NGK Iridium X-FRSportGrounding Plate-P2M SR20DET X-FRSportWiring Harness Service X-Wiring SpecialtiesAlternator Belt-Gates X-West Covina
EXHAUST--------------------------Apexi N1 Catback X-Phase2MotortrendDownpipe 3" flexpipe X-EbayTest Pipe X-Ebay INSTALLEDExhaust Manifold Wrap X-EbaySilicon Spray X-EbayExhaust Insulator Mount X-Courtesy NissanMeganRacing BMC Heat Shield X-Askem4parts
INTAKE---------------------------Circuit Sports Mini Catchcan X-EnjukuracingApexi Power Intake X-Askme4partsFuel Pressure Regulator -Fuel Filter-300ZX X-Performance NissanFuel Lines-Upper/Lower Steel X-Eric's Performance Parts Fuel Pump-Walbro X-Ebay
COOLING--------------------------S13 Radiator Cooling Panel X-EbayOEM S14 Water Outlet/Neck X-West Covina NissanRadiator-Koyo Racing Aluminum X-EbayRadiator Hose-Lower OEM X-Performance NissanRadiator Hose-Upper OEM X-Performance NissanRadiator Cap-Apexi X-EbayAltima Dual Fans X-Peays Junkyard Fan-Permacool Electric X-EbayDIF Dual Fan Relay X-Phase2MotortrendThermostat-NISMO X-EbayCoolant Temp Sensor X-AutoZoneTemp gauge Sender X-AutoZoneWater Wetter 12oz. X-EbayWaterPump-OEM X-Phase2MotortrendHeater Hose Kit-Heavythrottle X-Heavythrottle
GAUGES---------------------------Greddy Boost Controller X-EbayAlfa Otto Cluster X-Ebay INSTALLEDGauge Pod Center Dash XGauge-Boost X-Summit RacingGauge-Air/Fuel X-Summit RacingGauge-Oil Pressure XGauge-Water Temperature XGauge-Fuel Pressure X-Askme4partsOil Filter Sandwich Plate X-Ebay Doesn't fit...ebay crap!
GASKETS-------------------------- Gasket-Cometic Metal Head X-EbayGasket-Valve Cover X-Performance NissanGasket-Spark Plug x4 X-Performance NissanGasket-Thermal Intake Manifold X-Performance NissanGasket-Throttle Body X-Performance NissanGasket-Intake Collector X-West CovinaGasket-Idle Air Control Valve X-West CovinaGasket-Metal Exhaust Manifold X-Performance NissanGasket-Turbo 2bolt X-West CovinaGasket-Turbo 3bolt X-Performance NissanGasket-Turbo Outlet X-Performance NissanGasket-Turbo Compressor X-Performance NissanGasket-Transmission Rear Seal X-Courtesy NissanGasket-Transmission Gearbox X-Courtesy NissanGasket-Transmission Frnt Cvr. X-Courtesy Nissan
Modified by positron_ at 3:13 AM 12/22/2008
