It's been a while since I've given y'all an update...been busy with the end-of-the-semester crunch...
I apologize for the formatting of the text in this post; some of the pictures I used were ridiculously large...
Back at the end of summer, in the depths of my despondency, I wasn't even sure if I'd keep the car after it blew up after only 1000 miles on the freshly built, $3700 engine...
But I decided to keep it...she's my first and only car and I will have had her for 4 years this coming July.
So over Christmas break, I dropped off a spare block I got off of Foster (fiznat) at Precision Automotive in Simsbury...block got bored .020 over, surfaced, all that jazz, and rebuilt this time with CROWER forged connecting rods, not the crappy stock rods that apparently couldn't handle 16 psi from a small T3 @ 3krpm in 5th gear...
Anyway, the engine was ready by the time I got back for my spring break (March 10th)...so all that week, my dad and I were in the garage putting the engine back together/back in (I had the engine built only as a short-block). We had an uncharacteristically nice saturday (temps were 62 degrees in CT!!) so we were able to do it outside and benefit from natural sunlight.
While we were at it, my dad and I decided to move the oil cooler (for some reason I'm the only one I know who's actually running an oil cooler) from the front of the bumper, where it was wedged between the intercooler and AC condenser, to the passenger side of the bumper, where conveniently there was a huge air inlet. The oil cooler previously had been plumbed with just regular high temp, high pressure rubber oil lines and nipple fittings, but my dad said it was a failure waiting to happen and absorbed the (rather expensive) cost of upgrading the oil cooler lines to aeroquip, as well as the turbo drain line. Got a new sandwich adaptor plate (that fits in between the block and oil filter) that has an integrated thermostat from Mocal, with -10 banjo fittings already installed-before I was running a remote thermostat, which worked fine, but which also added a lot of unnecessary lines.
Also decided to FINALLY upgrade my T3 super 60, a turbo that wasn't exactly super (for my wants). If any of you remember, I praised this turbo for it's unbelievably quick throttle response and complete lack of lag, but lamented the boost drop-off and power waning past 5000 rpm. So I picked up another T3 super 60, brand new, internally wastegated still (yeah yeah, never got around to switching to external...too expensive, too complicated, yadda yadda yadda).
My old Super 60 had a .48 a/r stage 1 exhaust turbine and .60 a/r compressor, 60 trim. The NEW turbo is a .63 a/r, stage III turbine, 360 degree thrust bearing, 60 trim compressor, .60 a/r compressor. Got it brand new, including the external wastegate, from
http://www.mjmturbo.com for $500. This was not an off the shelf unit either-the guy I got it from had it custom made with the *strange* internal wastegate discharge assembly so I wouldn't need to re-do the downpipe. MJM turbo happens to only be about 20 minutes from my house as well; the guy was very nice about it all (he just owns a warehouse, he doesn't actually have a sales shop) and very helpful...incidentally, he went to MIT and owns both a skyline GT-R and a twin turbo lotus esprit v8 (he's pretty talkative!). This new turbo is quite a bit larger than the old one...here are some quick measurements of the outer diameter of the wheels:
Exh - Old=49.75mm, New=56.25mmComp - Old=52mm, New=60 mm
We were just able to get the car up and running before my break ended, and I was only able to take it out for a short ride because of the notoriously stubborn KA cooling system, which requires many short rides, massaging the upper radiator hose, unscrewing the bleed screw, scalding yourself, etc.
While I'm down here in school in Chapel Hill, NC, my dad's been breaking the engine in up North, and has already put 500 miles on it (we followed the gentle, ease-into-it break in method because that's how I broke the old engine in before, and after it blew up and we disassembled the engine, everything seemed to have broken in VERY well).
I won't be back home until about May 10th, so I can only experience the excitement of a revived KA-T vicariously through my dad's frequent "update" emails.
The car also needs to be brought through emissions (because, despite having OBD II, since the car's a '95, it needs to pass the sniffer...). It already passed once turbocharged with 370 cc injectors/JWT ECU, so hopefully it can pass again, despite having even larger injectors, a different MAFS, etc.
Anyway, here's a quick specification list (just the engine/ancillaries):
-forged wiseco pistons and rings, moly coated skirts, .020 over, 9:1 CR-forged Crower connecting rods-PDM stage II camshafts/shims-All new valve train (stock)-1 mm oversized Ferrea "super alloy" intake and exhaust valves-3 angle competition valve job-Cometic MLS head gasket-ARP head and main studs-Clevite main and rod bearings-new water pump, oil pump, timing chains, tensioners, guides, etc-JGS style log manifold, ceramic coated, flange cut between individual runners to prevent cracking, heavily ported by yours truly-2.5 inch mandrel bent steel downpipe w/flex pipe and a magnaflow glasspack!-2.5 inch mandrel bent stainless steel turbo inlet -JGS tools 26 inch x 8 inch x 3 inch tube and fin aluminum intercooler -2 inch aluminum hot-side piping, mandrel-bent -2.5 inch aluminum cold-side piping, mandrel-bent -Multi-ply high temp, high pressure silicone and stainless clamps used throughout -K&N cone air filter -Alcohol injection programmed to come on at 6.75 psi -Northern Tools and Equipment 1.0 gpm alcohol injection pump -Callaway turbo alcohol injection nozzle -Walbro 255 lph high-pressure fuel pump -MSD top-feed saturated 50 lb/hr (525 cc/min) fuel injectors, balanced and blueprinted -Aeromotive adjustable fuel pressure regulator (34 psi @ idle) -JWT Turbo ECU, for MSD 50 lb fuel injectors and Cobra MAFS -Aurora 8.5mm plug wires -NGK Iridium IX spark plugs (BKR7EIX-11) -Front-mount oil cooler, -10 aeroquip fittings, mocal thermostat-Koyo 2.1 inch all-aluminum polished radiator -Turbo XS Engineering bypass valve -Ford Cobra MAFS (1993). 3.5 inch inlet, 3 inch outlet -Phat KA-T billet aluminum top-feed fuel rail, 3/8" NPT, with Pegasus Auto Racing fittings
I'm only aiming for around 300 whp @ 14 psi or so (I don't need anymore, nor do I want to take any chances with more).
Anyway, onto some pictures!
Side view of the oil cooler w/o bumper:
Three large openings in the nismo bumper; all functional: one for the cold air intake, one for the intercooler, one for the oil cooler...my dad says the oil cooler almost works *too* well...water temp never gets above 180 (and this is just a standard 50/50 antifreeze/water mix), and that when he drained the oil after an 80 mile ride, it "didn't even burn my hands"
Pic of the Mocal sandwich plate adaptor/thermostat, without oil filter on:
Pic of the oil cooler/fittings, as well as the fine stainless steel mesh screen over the oil cooler...
This is a terrible picture of test-fitting the bumper with the oil cooler mounted, but you get the idea how it completely covers the opening:
This is an older pic of the car w/o the oil cooler on it, but it shows the three huge air inlets of the bumper that are now all functional:
Next on the modification list: an electrically controlled exhaust bypass valve, similar to the one I posted a while ago made by ATP, but this one is electrically, not boost, controlled, and is also $80 cheaper ($199)...This will allow me to run quietly, cleanly, and emissions friendly around town, and then run like a bat out of hell with all the benefits of running just a downpipe when I get into the twisties in the mountains...
That's it for now!
Modified by MarkEmark at 7:26 AM 4/10/2006
