Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Mon Jun 06, 2005 1:38 pm
Ok, driving impressions:
Well, being that the suspension is COMPLETELY stock, the car still handles very well to the added weight in the front. Actually, I haven't noticed a change in handling since it had the KA in it. But then again, it still is stock in that nature.
The car is just plain fast. Not only is it quick, it is very smooth. There is NO jerkiness in power, it is just plain in simple, smooth all the way to redline. Haven't really tested it out at the track yet, or even the drag strip. I want to get at least 500 miles on the clutch/engine before that.
The McKinney kit was pretty impressive. It was simple to use, fool proof, and does its job. Is it worth the $500+? Personally, yes because that part of the install was hassle free, compared to other people making their own and having problems. Also, the driveshaft was one peice of work. I haven't seen a better looking driveshaft to this day. And it was a perfect fit.
The engine sounds like a friggin' freight train lol compared to the KA. It is just simply mean sounding. Even coming to a stop, you can hear the turbos winding down, giving the whirling sound. What is completely different to me is having that extra 1000 RPMs. I am so stuck on shifting right at or even before 6500, that I am having to break that habit. So far, the farthest I haven taken it to is about 7100 RPMs, but I do not want to go ANY further until I put some more miles on it.
And, here is a funny thing. At the time we put the RB in and got it running, I haven't installed the recirculation kit for the HKS BOV. But, I am having ZERO problems running it atmospheric. There is no stumbling in RPMs after pressing and holding the clutch, or coming to a stop. It just goes to around 900-950 RPMs and stays there, no matter if I went to 7000 RPMs or if I was just driving normally.
The only real problem I had with this was a water pump leak. The one top center hole on the water pump is ovalish. Well, that 10mm head bolt sits on the far right side of that hole. Either the Permetex wore off or I didn't put any on at all below that hole, but coolant was leaking BADLY out of that hole. So, I took the bolt off, stuffed quite a bit of Permetex in there and placed the bolt in as well, let it dry/cure for about 2 days, and sure enough, all is good now.
If you have any other questions, please let me know. And thanks for all the remarks.
