matafied wrote:have you changed those plugs lol im sure you have
When you finally find what is causing this, b/c I would like to know. My rb20 swapped s13 does the same thing, only no backfiring.turbo corey wrote:if i put the throttle 1/2 way it will go to 8000 rpms with no problem.but if i go 1/2 throttle and then full throttle i back fires and then run like $hit....my tps at full throttle is 3.61v and just seting is .42v
holy sheet.turbo corey wrote:ok it was my timing on the intake side .it was off 1 tooth
