my RB20 problems all sorted out
JonPowell
Car: Cars, Music, My family
10 digit number is the part number
blk90s13
hmm so i guess i have a z mafs on my rb then its the same number
its not the mafs then cuz i already tried the Z32 mafs i got and it didnt change any thing
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
That 1st pic yes it should be pluged. unless you have a boost gauge then you can use that.
vududoc
Car: drag drift autox
the top 2 pics you posted:1st = boost gauge vacuum2nd = PCV4th= Speedothe other plugs connect to fuse box in bay.
blk90s13
and i need them all plugs right ?
there is a metal box ( looks like a transistor ) do i have to get that plug too ?
vududoc
that metal box is a dropping resistor...and yes you need that too.
blk90s13
ok i plugged that in and changed my fuel pump from a walbro to a jdm fairlady pump ( way too loud )
anyway i started the car it ran good at like 1500 rpm for about 30-40 seconds then shut off on its own now
i am thinking its fuel problem ? it was running very rough with the walbro at about 500 rpm then shut off
JonPowell
The Walbro is probably flooding it, the pump flows way too much volume...it is overrunning your stock pressure regulator....use the walbro, but get a new adjustable regulator
blk90s13
yeah that was the next step
i ordered a fuel pressure gauge from summit will install it this weekend and see wus up
42 should be the fuel pressure right ?
can it be done while car not running with ke in the ON position onle ?
Yellow4g63
I can't rem maybe I already asked but is the fuel filter new? or is your old KA one?
blk90s13
i have a Z filter that i had on my sr for about 3 month but i bought a new one along with brand new lines to start all over again
next thing i am changing my fuel hard lines it self
this thing is driving me insane right now
anyone in NJ willing to come give me a hand please i pretty much know it all but i just kind ran out ideas here
blk90s13
so no one in NJ willing to help out with some ideas ?
JonPowell
If you could somehow get it closer, I would love to help...you know I would!
blk90s13
i think my next option is bring it over to u and yes i know jon u would help deff
i was looking into the SR wiring cuz i had a SR in my car and the swap was done by someone other than my self so there is a black/yellow wire on the grey plug near the battery that is used on the SR swap its the idle air control where /wut color is it on the rb harness cuz its not hooked on my grey plug
also where is the idle adjust screw pm the throttle body i cant see it any where
JonPowell
The idle air controller is run through the RB upper harness....should be completely self contained.
Leave the idle adjust screw alone, it is a ***** to reset it nice nice.
vududoc
37 psi w vac 43 w/o vac
blk90s13
i think i am sell my car i am so sick of it wont run right
powell u free to look at it some time soon ?
i may trail it up to u in the next week or so and leave it there till its running
JonPowell
Come on up, I would love to get it running for you.
It looks like I may have something going on this weekend, but next weekend, the 19th is good for me...call me when you know your schedule for sure and we will get you handled.
