my radio wont work fuses are good!!!!
lilboobell22
Car: 2+2 nissan 300zx 5spd n/a
i blew my main fusible link last week got it fixed car runs now but the radio wont work the fuses seem to be fine could i of blown the deck????? or is there a fusible link for the radio everything else in the car work interior lights ect,ect,ect please help thanx.....
NissanFairladyZ32
Car: 91, Twin Turbo, 99 Miata 1.8L
same with me
everything else works but my radio has no power
... and all my fuse's are good
93, NA
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
is there power at the power wire in the back of the stereo? if you got power to the stereo but it doesn't come on, it's a bad stereo
Mean300zx
Car: 91 300zx
Same thing with my radio/in dash for the past days it only turned on wen it wanted to and when I went to go to work it didn't turn on or anything I checked the fuses there all good what could it be?
Trimble Epic
Car: White/Ivory 93 300zx NA 2+2 (RIP)
evildky wrote:is there power at the power wire in the back of the stereo? if you got power to the stereo but it doesn't come on, it's a bad stereo
Check this above first.
Pull the head unit out and find the 1) constant hot and 2) ignition hot wires... They should have 12v + when the key is on. If these wires do indeed have power, then the radio it what is broken...
Unless you also have amps. If the head unit comes on but you can't get any sound, then you have to check the wires leading to the amps just like above - check to make sure the wires leading to the amp(s) are powered... If so, you may have a broken amp.
300ZXttZMAN
Mean300zx wrote:Same thing with my radio/in dash for the past days it only turned on wen it wanted to and when I went to go to work it didn't turn on or anything I checked the fuses there all good what could it be?
Welcome to NICO!
I would have to agree^
BlackWidowZ
Car: Black 93 300zx 2+2
ya as the above said pull the radio out. go here with instructions on how to do that. The wireing diagram is in that thread use a multi meter to test the voltage of the wires. 300zx-stereo-installation-write-up-t572341.html
